start issues
Old May 11, 2015 | 11:40 AM
22655td's Avatar
22655td
Default start issues
I have a LS2 stroker in my 02 zo6,
It will start up perfect cold, after running it will not start the first cranking , it pops and snorts trying, you have to turn key off and the crank again and it start perfectly, Injectors not leaking down ( have psi gauge in fast rails) changed the filter.regulator, It has 65 psi of pressure and will hold that for about 1 hr before leaking down to about 20.
If it just cranks over 2 revs and you attempt again, it starts like it is perfect,
Any thoughts/
