I bought the eibach kit and lowered my car . The front looks a little lower but the rear doesn't . How long does it take to get the full effect,and will driving it speed the process up?
Drive the car for a few or several miles...over a couple of dips and speed bumps, small depressions in the road,etc, etc. It should settle in.
The car will always sit higher when you just drop it off the stands and don't move it.
Make sure you keep the original front bolts. Those poly pads on the lowering bolts will likely tear-up in about 10k-15k miles and your front suspension will start squeaking due to the metal on Al and then you'll want the stock ones back.
