Frost plug/cylinder head question
I just want some other opinions/thoughts on this before thinking of dropping that kind of $$
2. PLEASE mail me your old heads.
Ill pay SHIPPING!Seriously,,, If a freeze plug is leaking,,, why can it be repaired?
You have to ask your self,, WHY,,, was the freeze plug replaced? Did the engine FREEZE at sometime in its past? Was the plug just damaged?
Clean the engine/heads and inspect ALL the freeze plugs. Find the leaker. Fix it correctly. Use a mirror and a good strong light. The correct way is to pressurize the coolant system with a pump and do the inspection. Do the inspection and see where the leak is.
Can you do your own work? If not, find a competent C5/C6 specialty Shop and see what they will charge you for the repair. You don't need no stinking STEALERSHIP!
90K miles isn't much for a C5?? Where do you live???
BC
