Misfires
Old May 19, 2015 | 09:56 PM
Trios's Avatar
Trios
Default Misfires
Evenin' gents.
My car has been running great recently. I installed Torque on my new Android head unit, and was adding some sensors to the screens, when I saw that the misfire counters were crazy high.
The 'history' counters ranged from a low of 62 to a high of 850. The 'current' counters would have some values when I started the car, and then they would all go to 0 as I drove, except cylinder 6. Cylinder 6 is always showing at least 2 'current' misfires. It's also the one with the highest historical misfires.
There is no CEL, the car doesn't seem to miss, as I said it runs great and has lots of power.
I checked Torque on my Trailblazer, all 6 cylinders have 0 historical or current misfires, which is what I would expect to see on a healthy engine.
Any ideas on whether I should even try fixing this or what I would do to do so?
Old May 19, 2015 | 10:04 PM
4DRUSH's Avatar
4DRUSH
Is your Vette really pink?
Old May 19, 2015 | 10:11 PM
Trios's Avatar
Trios
Hmm. Is this a trick question?
If I say yes, will you not help me fix my potential misfire problems?
Ah, screw it.
My car:
Old May 19, 2015 | 11:35 PM
4DRUSH's Avatar
4DRUSH
Start with plugs & wires
Old May 20, 2015 | 12:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LMAO.. That made my day!!
When was the last time you changed the plugs. If the plug gap is excessive, it can raise the misfire count and still seem to run fine. Plugs degrade over a long period of time
If you change plugs, most of the time you damage the OEM wires. My recommendation would be to obtain a set of GM Performance Red Wires from Gene Culley at CULTRAG Performance.
They are excellent wires and the fit quality and performance is second to none. They don't cost much either!
Old May 20, 2015 | 12:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ALSO SEE THIS POST for additional troubleshooting assistance:
https://www.corvetteforum.com/forums...miles-wth.html
Old May 20, 2015 | 01:57 PM
Trios's Avatar
Trios
I replaced the plugs about 30k ago, but I did not replace the wires. I'll do them both again (relatively inexpensive as far things on this car go) and see how it goes.
Thanks guys.
Old May 20, 2015 | 02:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks guys.
Just pull the plugs and examine them. Check the GAP. If there still good, there good. If their shells are not cracked, there should be no reason to replace them.
What GAP did you run them at?
Old May 20, 2015 | 03:12 PM
Trios's Avatar
Trios
I bought the AC Delco Platinums and checked their gap, they were right at .040 when I installed them.
I have 136k on the car (76k mine), the wires may be original or they at least have 76k on them.
I'll replace the wires and pull #6 plug (since it's got the highest misfire counts) and see what it looks like.
Old May 20, 2015 | 09:33 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referral. We would certainly be happy to help out.
Old May 20, 2015 | 09:35 PM
Trios's Avatar
Trios
Ha. I ordered a set of C6Z06 shocks and GM Performance wires from you about 3 hours ago Gene
Old May 20, 2015 | 11:08 PM
Gene Culley
Thank you for the opportunity to earn your business. We'll process your order tomorrow and let you know what's going on.
Old May 21, 2015 | 12:30 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any time my friend... I have ALWAYS received great service from you and Patrick and very good prices..
Old May 21, 2015 | 10:19 AM
chevy406's Avatar
chevy406
Trios - do you have the stock camshaft in your engine? Is the PCM re-tuned from stock?
A longer duration camshaft lope will register to the PCM as "misfire". When re-tuning for the new cam the misfire table values can be increased to desensitize what the PCM considers a misfire. Many tuners simply turn OFF the misfire Check Engine Light, but then the operator doesn't get any notification when there is an actual problem. Hopefully the new plug wires make cylinder #6 happy again.
Old May 21, 2015 | 10:44 AM
Trios's Avatar
Trios
Motor is stock, but the PCM does have a mail-order tune.
I know I've gotten a CEL for P0300 (random misfire) before, but it's happened very rarely on startup on extremely cold days, and went away immediately, so I never thought much of it.
How many misfires does it take to set the CEL?
Old May 21, 2015 | 02:42 PM
chevy406's Avatar
chevy406
..How many misfires does it take to set the CEL?
There are 7 misfire tables that list "maximum time between events to declare a misfire". The tables are split between "Event Mode" and "Revolution Mode". The "Y" axis is RPM and the "X" axis is 17 columns of some value from 0 to 100. These tables are further divided into idle, medium, and high RPM.
So there isn't a simple answer to your question. But I can say that a longer duration cam with noticeable idle lope will eventually set off a misfire code unless the tables are increased in the idle areas.
If you are showing one cylinder with particularly higher misfire, then try swapping the plug wire; plug; coil (in that order) to see if the misfire moves to another cylinder. Then replace the component that was causing the misfire. I've accurately diagnosed several cracked plugs and bad wires by scanning individual cylinder misfires.
On a couple other occasions I had to pull the valve cover to discover a broken spring or broken rocker arm. But you can feel that there is a dead cylinder when that happens.
Old May 21, 2015 | 03:22 PM
ZZ06's Avatar
ZZ06
Wish i had a scanner to monitor this myself. It would help me furhter diagnos the problem im having vs R2ing all 8 coil packs (not doing this as of yet). What kind of scanner are u using??
To Misfires
Old May 21, 2015 | 03:34 PM
Trios's Avatar
Trios
Do you have an Android smart phone or tablet? If so, you can pick up a cheap Bluetooth OBDII adapter and run Torque. It can scan all generic and most GM-specific PIDs (with the ability to add custom PIDs), perform logging, clear codes (not that we need that for the 'Vettes, but it's useful on my Trailblazer), etc. Pretty damn handy app.
Old May 21, 2015 | 03:43 PM
ZZ06's Avatar
ZZ06
Your joking right? Wow never knew this! Will have to look into this!
Old May 21, 2015 | 03:57 PM
Trios's Avatar
Trios
First you purchase
something like this something like this
Then you purchase and install Torque Pro
Then you connect to the Bluetooth adapter and start playing around
