tars8car
Old Jun 4, 2015 | 05:30 PM
tars8car's Avatar
tars8car
4th Gear
Default tars8car
Hello new here, I have a 98 Corvette alway's stuck with C3's but got a C5 and 3 hr's in to it got a p0420 code and noticed it doe's not have cat's on it . I'm in Oklahoma and we do not have State Insp. but to correct problem do I need to replace the cat's?
Old Jun 6, 2015 | 02:22 AM
SG Lou's Avatar
SG Lou
this might shed some light on the subject : https://www.corvetteforum.com/forums...ode-p0420.html
A code P0420 may mean that one or more of the following has happened: Leaded fuel was used where unleaded was called for A damaged or failed oxygen sensor (HO2S) Downstream oxygen sensor (HO2S) wiring damaged or connected improperly The engine coolant temperature sensor is not working properly Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe Retarded spark timing The oxygen sensors in front and behind the converter are reporting too similar of readings Leaking fuel injector or high fuel pressure Cylinder misfire Oil contamination
Possible Solutions : Some suggested steps for troubleshooting a P0420 error code include: Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required. Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady). Inspect the downstream heated oxygen sensor (HO2S), replace if necessary Replace the catalytic converter Overall probably the biggest mistake vehicles owners make when they have a P0420 code is to simply replace an oxygen sensor (H02S). It is important to do proper diagnosis so you're not wasting money replacing parts unnecessarily. We strongly recommend that if you need to replace the catalytic converter that you replace it with an OEM unit. Second choice would be a high-quality replacement part. There are many stories in our forums where folks replaced the cat with a cheaper aftermarket one only to have the code return shortly thereafter. One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
Old Jun 6, 2015 | 11:54 AM
tars8car's Avatar
tars8car
4th Gear
Default tars8car
Thank you
Old Jun 6, 2015 | 11:57 AM
tars8car's Avatar
tars8car
4th Gear
Thank you next time I will just keep the C3 easier to work on for a shade tree, old school non tech.
To tars8car
