'vettes throwing a code: P0420
Old May 1, 2009 | 01:48 AM
And7Baller's Avatar
And7Baller
Default 'vettes throwing a code: P0420
This code has been coming up quite a bit. I've reset it a few times but it always comes back after a day or so.
I looked up what the code meant is this is what I got:
P0420 TWC System Low Efficiency Bank 1
I then searched around and pretty sure it means my left cat is bad? I can't tell that anythings wrong with the car while driving, everything seems to be fine. Is this something I need to get checked out soon? I read that a lot of people just clear it and continue on like it's no big deal. I love cars but I'm defiantly no expert on them. In fact, I'm not even really sure what a cat does to tell you the truth. Any kind of help is appreciated. Thanks!
Old May 1, 2009 | 06:49 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I get the same code, I'll have to look that up again, thought is was the air pump??
after 130k miles the left cat went?? could happen.
Old May 1, 2009 | 09:20 AM
vettenuts's Avatar
vettenuts
If the car is basically stock and high mileage, likely the stock converters are on the way out. With the number of people here who have gone to headers, you should be able to pick up a low mileage mid section for cheap with basically new converters. If you were at Carlisle, you could get them for free as the header installers usually fill the dumpsters with stock mid-sections every night.
Old May 1, 2009 | 12:57 PM
And7Baller's Avatar
And7Baller
Yeah, I'm getting close to 80k miles. Guess that makes sense.
Old May 1, 2009 | 03:48 PM
vettenuts's Avatar
vettenuts
Throw a post in the for sale section, a lot of guys give them away to get them out of their garage.
Old May 1, 2009 | 04:11 PM
SteveDoten's Avatar
SteveDoten
mufflers yes; there was only tent installing headers, not one midpipe was tossed, not one.
Old May 1, 2009 | 04:13 PM
slothy's Avatar
slothy
cats are worth coin used
Old May 1, 2009 | 07:28 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
P0420 and P0430 are the rear O2 codes. If stock, it's telling you the cats are going. Just as mentioned.
Old May 1, 2009 | 09:18 PM
vettenuts's Avatar
vettenuts
First year LG installed, they were stacked like cord wood. My friend left his there as well.
Old May 1, 2009 | 11:53 PM
KRISCO's Avatar
KRISCO
Its either a cat or a rear sensor. You can swap sensors to see. Bang on the cats with a rubber mallot. If you hear pieces bangin around, you got a bad cat. Mine went at 7200 miles.
Old May 1, 2009 | 11:55 PM
KRISCO's Avatar
KRISCO
You can drive the car by the way. It just wont pass the sniffer test
Old Feb 24, 2020 | 08:23 PM
David Connolly's Avatar
David Connolly
1st Gear
Default P0420 Codes
I know this post is a bit old but I just got code P0420. Car is due for inspection but check engine light is on so I will fail.
can a novice reset this code if it’s just a “warning” for bad cat?
Old Feb 24, 2020 | 10:09 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
You can reset it but it will most likely come back. There are a few ways you can fix this.
1. Change the catalytic converter.
2. Install a spark plug anti fouler where the rear O2 sensor goes and then install the sensor
3. You can also alter the signal to the PCM by soldering a 1 Meg resistor in seriies with the O2 sensor + signal and 1 microfarad capacitor (PCM side of resistor) into the wiring of the O2 sensor..
4. Tune out the rear O2 sensors.
Old Feb 25, 2020 | 07:59 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Dave, without some diagnostic equipment a novice is not going to be able to diagnose this concern without firing the parts canon !!...here are 2 videos that can give you a little more info...find yourself a good diagnostic shop !!...good luck !!
Old Feb 25, 2020 | 10:09 AM
jjc508520's Avatar
jjc508520
I was thinking vacuum leak - but looks more like the cat or O2 sensor....
https://www.obd-codes.com/p0420
To 'vettes throwing a code: P0420
