O2 sensor Needs replaced
Old Jun 10, 2015 | 05:00 PM
gmerrill's Avatar
gmerrill
Default O2 sensor Needs replaced
Where is the Bank 1 oxygen sensor 2 located on a 2002 C5? I need to replace it. Thanks for your help.
Old Jun 10, 2015 | 05:45 PM
xdmikey's Avatar
xdmikey
In for an answer.
Old Jun 10, 2015 | 05:54 PM
grantv's Avatar
grantv
Bank 1 = drivers side
Bank 2 = passenger side
Sensor 1 is directly after exhaust manifolds/headers to maintain proper A/F ratio
Sensor 2 is after cats to confirm cat is working correctly
So yours is the drivers side sensor plugged in after the cat. Keep in mind the wiring crosses over, don't get them mixed up. Most people running aftermarket cats/headers/no cats have the secondary O2 sensors "tuned out".
Old Jun 10, 2015 | 07:26 PM
gmerrill's Avatar
gmerrill
Thank you very much. Great response.
Old Jun 10, 2015 | 09:20 PM
grantv's Avatar
grantv
NP. How are you positive it's the sensor? A code will only tell you it's either the sensor or the cat AFAIK.
Old Jun 11, 2015 | 12:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please post the DTCs that sent you into the O2 sensor direction. Remember,,,, O2 sensors have different failure modes:
- Defective Sensing element
- Defective/non working heaters.
- Defective/Damaged wiring and or connectors
- PCM reference voltage not working
Before you throw in new sensors, I strongly recommend obtaining a VOLT/OHM meter and making sure that you have proper heater voltages at the fuse test points and proper ground.
Here is the circuit that you will be dealing with:
Notice that the voltage to the circuit is ONLY SUPPLIED when the IGNITION SWITCH is ON. Make sure that there is full battery foltage available at that fuse.
Old Jun 11, 2015 | 07:40 PM
gmerrill's Avatar
gmerrill
Thanks, I will make sure that I have proper heater voltages at the fuse test points and proper ground.
To O2 sensor Needs replaced
