Msd 2 step question
Old Jun 15, 2015 | 09:46 PM
rttmike's Avatar
rttmike
Default Msd 2 step question
Guys that have used the msd 2 step. Did you tap into your factory clutch switch? Or install a second switch?
Old Jun 16, 2015 | 09:38 AM
rttmike's Avatar
rttmike
And does anybody know if our clutch switch is a ground switch or 12 volt switch?
Old Jun 16, 2015 | 02:01 PM
junk c5's Avatar
junk c5
I tapped into my brake light switch. I've got an auto. The signal wire is on a toggle so after I release the brake I shut off the toggle. Obviously otherwise if I tapped the brake the 2 step would activate. At least thats the theory, I haven't tapped the brake with the 2 step activated while making a pass..
Old Jun 16, 2015 | 02:08 PM
rttmike's Avatar
rttmike
Thanks for the info. But I really want this tied into my clutch. I'm just not sure if the clutch switch completes a ground circuit. Opens a ground circuit. closes a 12 v circuit. Or breaks a 12 v circuit.
Old Jun 16, 2015 | 03:16 PM
4DRUSH's Avatar
4DRUSH
Won't you need a momentary switch on the shifter, activated by the position of 1st gear also?
Old Jun 16, 2015 | 03:29 PM
rttmike's Avatar
rttmike
Not on this setup. This is in the instructions provided..
The LS 2-Step has a built-in rpm drop circuit that prevents the low rpm limit from activating during gear shifts (when connected through the clutch switch). In order for the limit to activate, it must see an rpm drop of more than 1/3 the set amount. For example, if the limit is set at 3,000 rpm, the limiter will not activate unless it sees more than a 1,000 rpm drop.
Old Jun 16, 2015 | 09:29 PM
junk c5's Avatar
junk c5
You could activate it on a push button like a trans brake. That was my other option. I'm sure somebody will post a schematic shortly...
Old Jun 16, 2015 | 09:48 PM
rttmike's Avatar
rttmike
I did some testing and may have figured it out. Purple wire on the clutch switch is the wire that needs to be grounded to make the starter turn over. Maybe others can shed some light but it looks like it is a normally open ground switch??
Old Jun 16, 2015 | 10:49 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I,m pretty sure that the clutch switch is to complete the circuit to the starter solenoid !!!!
Old Jun 16, 2015 | 11:54 PM
rttmike's Avatar
rttmike
I understand. But I need something to tap into for a signal wire to the 2 step.
Old Jun 17, 2015 | 08:46 AM
rttmike's Avatar
rttmike
Thank you. I'm not good at reading these things. But is it safe to say that when the clutch is pushed, the purple wire coming out of the clutch switch is grounded?
Old Jun 17, 2015 | 09:15 AM
rttmike's Avatar
rttmike
OK. Thank you. This switch won't do what I need it to do then. My msd will let me trigger with either a ground or 12 volt source. Looks like I will need to add a switch of some type to the clutch pedal.
Old Jun 17, 2015 | 11:14 AM
rttmike's Avatar
rttmike
What I need is either a ground or a 12 volt source when the clutch pedal is down to the floor with the car running.
http://www.msdignition.com/WorkArea/...id=15032386403
Old Jun 24, 2015 | 10:10 PM
rttmike's Avatar
rttmike
I just figured out that there are two clutch switches. One way up under the dash. And one mounted to the firewall. I want to know about the one on the firewall. What does it do? Is this the one pictured in the diagram?
Old Jun 25, 2015 | 08:10 AM
rttmike's Avatar
rttmike
If you look you will see it. There are for sure two of them. One is tucked up high under the dash.
Old Jun 25, 2015 | 09:37 AM
ascastil's Avatar
ascastil
I know what you are talking about. The white switch by the knee bolster part. Clutch position sensor I think. I had a code for that once when I put in my Tick master cylinder. Not really sure how it works though. Free bump.
Old Jun 25, 2015 | 10:29 AM
rttmike's Avatar
rttmike
OK gotcha. Thank you for the clarification.
I still need to figure out this dang 2 step lol.
To Msd 2 step question
