Headlight gremlin
Old Jun 16, 2015 | 06:32 PM
Bluebeast17's Avatar
Bluebeast17
Default Headlight gremlin
Ok guys I'm lost,i have a04 car right turn signal went out,Changed bulb headlight quit going up n down checked fuses they are good took bulb back out they still don't work they come on but don't open or close.
Have power to the headlight modulator but changed it to see if it was bad still nothing,
I'm at a loss any help would be appreciated.
Old Jun 16, 2015 | 08:19 PM
betterthanabike's Avatar
betterthanabike
Cruising
working on a similar but slightly different problem right now. very frustrating. check out my thread "new bcm? yikes"
Old Jun 17, 2015 | 07:24 AM
dadaroo's Avatar
dadaroo
Manually raise them and then see if they will go down.
When you say you checked fuses it would help us if you told what fuses and whether you actually tested them or not.
Old Jun 17, 2015 | 08:00 AM
Bluebeast17
Default I did
I actually checked each fuse in both fuse boxes with a tester especially#44 under the hood and#6 in the passenger kick panel,checked the grounds they all are in great shape so I'm just looking for new things to check.
Old Jun 17, 2015 | 10:56 AM
dadaroo's Avatar
dadaroo
Just to make sure I'm clear, is it both doors will not move or just the passenger side?
Also did you actually verify you had power "at" the HL module and not just that fuses 3 and 4 are good?
If the HLs come on I doubt it is the MF switch but I'm not ready to rule it out yet.
If you have Twilight Sentinel turn it ON and cover the light sensor in the Defrost vent in front of the driver. That would be a helpful diagnostic. In this case the MF HL switch would be in the OFF position.
Hopefully it is not the BCM.
I can provide the schematics if you need to get serious with chasing the wiring and connectors.
Mr. Sam
Old Jun 17, 2015 | 11:37 AM
Bluebeast17
Thanks Mr Sam I did as you said and nothing ,To clarify yes it is both doors and I checked the leads at the headlight module and even changed the module itself twice just to be sure since it was a used module,i've checked the grounds they are in great shape.All fuses look good I'm totally at a loss
Old Jun 18, 2015 | 06:43 AM
dadaroo's Avatar
dadaroo
Too bad you don't have TS to use.
The HL gets the "ON" signal by the IPC applying 12 V to the HL module using the White wire.
You can try and see if they will work by applying 12V to that White wire at the module.
Based on what happens we can proceed from there.
The IPC Dimmer switch provides that White wire input. Weird, but that is what the schematics show.
Old Jun 25, 2015 | 10:14 PM
dsword's Avatar
dsword
2016 C6 of the Year Finalist
Default Didn't open, then worked...
I'm interested in hearing more about opening them manually, then turning on and off. My didn't open tonight, so I cranked them open, then turned the switch back off and they closed perfectly and have worked properly another ten times... Do they get out of synch or something?
Old Jun 25, 2015 | 10:55 PM
Bluebeast17
Well I wish that was my problem,i changed headlight module next one they worked exactly backwards turn headlights off they came up but lights off turn them on they closed and lights came on, changed module again and now like before nothing happens go figure that one.
Old Jun 26, 2015 | 07:01 AM
dadaroo's Avatar
dadaroo
That would tell me you have a module problem with both of them. If that is all you changed and one did nothing and the other did the opposite. That would seem to rule out the MF switch feed and the IPC dimmer switch feed.
To Headlight gremlin
