Need help with Electrical problem
Old Jun 21, 2015 | 01:54 PM
19vette91's Avatar
19vette91
Default Need help with Electrical problem
I have a low mileage 2002 ZO6 that has an intermittent problem with my turn signals. Most of the time they work fine, but every so often neither one works while out for a drive, then after a while when still on the same drive they work again after 10 minutes or so.
Today when it happened again, I tried my hazard lights which came right on, turned them off and retried the turn signals and they came on.
No codes are showing. Can anyone shed some light on a fix?
Thanks!
Old Jun 21, 2015 | 02:26 PM
fishdude7's Avatar
fishdude7
Replacing the hazard light switch should fix your problem. I have the same issue with my c5. When the turn signals don't work press the hazard light switch quickly a few times, and the turn signals should work again.
Old Jun 22, 2015 | 11:55 AM
dadaroo's Avatar
dadaroo
I agree you most certainly have a Hazard switch issue if the problem is with both turn signals. Never seen an MF switch to cause an issue in both directions, but you never know with Murphy. Suggest you go for the Hazard switch.
I did the relocation so now I can replace it in 30 seconds and the dash looks stock. Easy to reach if you need Hazards. It is in my write up that 8VETTE7 posted above. You can do it without removing the existing switch if you buy the short harness I also provide info on.
To Need help with Electrical problem
