Service Vehicle Soon
Old Aug 17, 2002 | 11:13 PM
SvenOdin's Avatar
SvenOdin
Default Service Vehicle Soon
Every few days (100 miles or so?) I get the "Service Vehicle Soon" display on the DIC. I changed my oil less than a month ago, and the level is fine. There was the U1016H error code, but I contribute that to when I installed the Blackwing and had to remove the fuses for the PCM and do the intake/PCM recalibration. No other codes in history.
Any idea's on why I keep getting this message?? :confused:
:cheers:
Old Aug 17, 2002 | 11:19 PM
redriverjohn's Avatar
redriverjohn
Default Re: Service Vehicle Soon (SvenOdin)
Well, you might try clearing the old codes and then checking to see if any new ones are being set.
Old Aug 18, 2002 | 12:53 PM
SvenOdin's Avatar
SvenOdin
Default Re: Service Vehicle Soon (redriverjohn)
Did that. No other codes appear after almost a dozen ignitions.
I've also had the "Coolant level low" warning, however, the level is fine. Whenever I get this message, I'm parked on an incline.
Old Aug 18, 2002 | 01:40 PM
carpe dm's Avatar
carpe dm
Was your gas cap on tight? It might set this code, as part of the emissions program. :yesnod: :)
Old Aug 18, 2002 | 09:51 PM
Red C8 of Jax's Avatar
Red C8 of Jax
I have the same problem. Took car to Chev Dealer and they found the battery leaking. Removed acid, said the PCM was OK and after $400.00 and a new battery I still get the Service Veh Soon. Usually after about 35 min of driving without turning car off. Let me know If you have any luck.
Old Aug 19, 2002 | 01:12 PM
jerryv's Avatar
jerryv
The 1016 is unrelated. All the 10xx codes relate to communications problems .. which are usually intermittent and can usually be cleared with no recurrence. If the car is usually on an incline, I'd be 'inclined' to think that it has something to do with one of the fluid levels .. coolant, brake fluid, etc. You'd think that a code would be set, though... :confused:
Old Aug 22, 2002 | 08:04 PM
SvenOdin's Avatar
SvenOdin
Default Re: Service Vehicle Soon (red-C5 of jax)
100 miles has passed since last notice, and like clock work, notice appears on DIC once again. This is really confusing :confused: not to mention frustrating :cuss No codes :crazy:
Suppose I'll have the oil and coolant changed this weekend and see if that resolves the problem.
Old Aug 22, 2002 | 09:28 PM
Red C8 of Jax
Let me know your results. I think the engine is fine and the computer is mixed up. :mad
To Service Vehicle Soon
