Engine sputters during WOT?
Old Jun 24, 2015 | 07:54 AM
corvet786c's Avatar
corvet786c
Default Engine sputters during WOT?
Any ideas what it could be? Its a 2002 automatic highly modified with supercharger.
On take off at Wide open throttle after 3500 rpms its sputters or shakes a bit. Am I running only on 7 cylinders? Would this typically happen. I did get a P0200 code a week ago but had a faulty fuel injector. Need thoughts Thanks
Old Jun 24, 2015 | 09:25 AM
4DRUSH's Avatar
4DRUSH
Take it to a tuner & have them log the vitlals.
Old Jun 24, 2015 | 10:19 AM
corvet786c's Avatar
corvet786c
10-4 I am going to take it to the dealer on a tech 2 and see what's going on.
Old Jun 24, 2015 | 10:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
Good luck with that. I suggest you find a qualified tuner and have them look at the car. Highly modified and supercharger is certainly not something a Stealership deals with many times if ever........
STEALERSHIP!?! That would be the very LAST place I would take a highly modified car to!
If it were MY car,,, The very first thing that I would check and or change are the sparkplug wires and sparkplugs.
The last time that I helped someone who lived in France with the EXACT SAME ISSUE,, the very first thing I asked him was: " What are the conditions of the plugs and wires?" He stated they are NEW!
After a week + of having him check EVERY POSSIBLE THING THAT COULD CAUSE MULTIPLE RANDOM MISFIRES, he offered to fly me to France to fix his car!!
Before I accepted that EXPENSIVE outcome, I asked him to remove a plug and send me a picture of the condition of the plug. I wanted to see if I could see fire ring on the insulator.
The plug was the wrong one for a FI Set Up and they were ALL FOULED black!
New correct Sparkplugs solved his issue. Damn, I was so much wanting to visit France!!
SO,,,, When was the last time you looked at the SPARKPLUGS and WIRES??
Bill
Old Jun 24, 2015 | 11:01 AM
corvet786c's Avatar
corvet786c
Bill
Thanks Bill, They are NGK TR 6 plugs. I recently changed them and look at them about a month ago. And they looked brownish at the time. I am using MSD 8.5 conductor plug wires, They are also new about 2 weeks ago. The gap on the plugs are .35
Unless I should not run a tech 2 on the car please let me know. Not getting other codes other than that P0200 which I believe was a faulty fuel injector. Haven't got it since a couple of weeks ago.
Wondering would a hairline fracture on the plug cause this as well?
Old Jun 24, 2015 | 11:43 AM
4DRUSH's Avatar
4DRUSH
MSD wires are junk
Faulty injector could blow your motor
Replace the plugs & try not to crack them (again)
Old Jun 24, 2015 | 11:46 AM
corvet786c's Avatar
corvet786c
Originally Posted by 4DRUSH
MSD wires are junk
OK, I will cancel my appointment check spark plugs again for the 2nd time.
Old Jun 24, 2015 | 12:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL! The last time I had a cracked plug, I thought the engine was going to drop out of the engine bay. LS engines DO NOT like misfires!
A cracked plug is NOT going to cause you a P-200 DTC.
Recommend that you find the FUSES and REALY that provide POWER to the Injectors and COILS and make sure that they are:
1. Not loose, corroded in the fuse box slot.
2. Check the ACTUAL voltage being supplied to and from the fuse by reading the TEST POINTS on top of the fuse to chassis ground If it not full battery voltage, you are going to have issues.
3. Check the coil and injector wiring harness that runs down the drivers and passengers side of the engine between the heads and intake manifold. Make sure that its not damaged and has exposed wires. Especially in the area where it bends around or use to bend around the black metal bracket behind the drivers side fuel rail.
Fuses and relays:
Coils:
Old Jun 24, 2015 | 12:19 PM
73Corvette's Avatar
73Corvette
Might check with Gene at Cutrag and get some GM Red Performance wires, plugs and heat sox while your at it...
http://www.cultragfactoryparts.com/
Old Jun 24, 2015 | 12:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your wires are bad, damaged or questionable,, that's exactly what I recommend using for wires.
If the wire, and boot insulation is good and they still SNAP properly on the coil and plug and you can OHM out the wires end to end and see very low resistance (I think MSD advertises like 20 ohms resistance) on every wire,, the wires are good for now.
I still prefer and use GM Performance RED wires!
Old Jun 24, 2015 | 01:54 PM
Cheesecake 07's Avatar
Cheesecake 07
Good advice so far. Never a bad idea to check your grounds. I had some high rpm sputtering issues not too long ago...ground to the back of drivers side cylinder head had worked itself loose. Wasnt getting any codes.
Old Jun 24, 2015 | 02:22 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT Recommendation!!!!
If you look at the injector schematic, you will see that G-106 is that ground and YEP,,, that ALSO can cause a P0200 DTC
Heres what it looks like attached to the head (head is removed for mods )
Old Jun 26, 2015 | 01:17 PM
corvet786c's Avatar
corvet786c
Thanks for all the help and replies, *Problem fixed*
Under boost and massive fuel from the custom tune, it was blowing out the spark. I had to close the gap some on the spark plugs. From .35 to .22-.25, Idle is much better and does not sputter as bad. from a 50 mph roll.
To Engine sputters during WOT?
