Heads getting ported !!
When I get them back it'll be time for a BIG TIME swap.
Newly ported heads, FAST 92mm intake, LS2 90mm TB and an EG Whiplash cam.
YEAH BOY !!
What pushrods are you going to be using?
Did you do any rocker trunion up-grades?
Are you going to use NEW LIFTERS? What Type?
Did you order and install new lifter buckets?
Recommendations:
1. Order and install ARP Head Studs. Far superior to the torque to yield OEM bolts & you lessen the chance of stripping out the threads in the engine block
2. MAKE 100% absolutely positive, without a doubt sure that there is NOT ANY liquid inside ANY of the head bolt holes in the block before you install ant head retaining bolts!!!! IF YOU DONT, YOU CHANCE RUPTURING THE BLOCK!!! I use the LONG wooden stem Q tips and probe the hole. If it comes out dry and clean, your GOOD!
3. APPLY RED LOCKTITE (high strength thread locking compound) to the three bolts that secure the cam gear to the cam! If you don't, they will most certainly come loose! Murphy said so!
4. When you install the FAST INTAKE, MAKE SURE that you swap in the low profile valley cover bolts. Lay the manifold on the heads without bolts. If it doesn't sit FLAT on the heads without bolts, its hitting something that needs to be addressed before you torque it in place!
5. The front cover gasket can be installed in either direction. HOWEVER,, there is only ONE correct way! Make SURE that you put it on in the correct direction! If you don't, you WILL have a BIG oil leak! Pre oil the LIP of the damper seal with oil.
6. While the water pump is removed, its a PRIME time to SUCK out all the old coolant from the block. I use a wet and dry vac with a tygon hose extension tapped to the hose. With ALL the OLD coolant removed, you can refill the block with pre diluted dexcool& distilled water at the correct mixture for your area.. Good time to install a new T stat at a lower operating temp. I used the 180 deg stat.
7. Extend your vacuum line at the back of the intake. My FAST 90 had a small vacuum port on the passengers side of the intake that I used for the vacuum source.
8. I also moved my MAP sensor with a map relocation kit. Makes life a LOT easier and works very well.
9. If your block is factory drilled for the timing chain dampener, I highly recommend installing one. SOme late model blocks are factory drilled. The dampers are being manufactured again by aftermarket:
Some pictures for you:
ARP HEAD STUDS INSTALLED
I have a 2002 LS6. The late model LS engines did NOT have a rear steam cross over pipe. I added one using a late model FRONT cross over pipe and connected it with a rubber hose at the front:
MAP Relocation Kit:
New CADDY Racing Lifters in New GM Lifter Buckets:
New LS2 Timing Chain vs OLD Crappy LS1 design:
LS-1/6 Timing chain damper:
Extended vacuum line at back of manifold:
Good Luck my friend and have fun with the MOD process... Who will be TUNING the PCM??
Bill
What pushrods are you going to be using? Chrome moly 7.4
Did you do any rocker trunion up-grades? Purchased roller rockers
Are you going to use NEW LIFTERS? What Type? New Crower roller lifters
Did you order and install new lifter buckets? Nope, will get some
Recommendations:
Was going to use new ARP head bolts
Will do.
Will do.
Already have themo.
Will do.
Plan on draining and refilling the entire system.
Will look into that.
Plan to relocate to the front of the intake.
9. If your block is factory drilled for the timing chain dampener, I highly recommend installing one. Some late model blocks are factory drilled. The dampers are being manufactured again by aftermarket:
Planning on taking the car to EG in Houston.
Bill
With an EG Tune, I was able to get 450RWHP...
I still strongly recommend head studs...
Tell EG and Jason, Bill said HEY!
When your all said and done, please post results! Tell EG you want a Video...
And what's wrong with ARP bead bolts ??
No torque wrenching required ??
ARP anything that will see a torque value, I ALWAYS use ARP lube.
Very helpful.
Once you install a set of heads using studs, you will NOT want to use anything else.
BC
The repair is time consuming and the TINECERT Kit is expensive.
When you use OEM Torque To Yield bolts, you are MOVING the bolt at the same time as you are stressing the threads in the vertical direction.
This causes a LOT of stress on the threads in the block. Sometimes they give way. The feeling is HORRIBLE!
With head studs, you eliminate that twisting stress on the block threads.
If you came to me and said,, Bill,, help me install a set of heads. I would tell you to ORDER Head Studs and I will..
Once you see how NICE it is to use the studs, you will NEVER want to use OEM TTY bolts again..
BC
http://www.ebay.com/itm/LS1-Cylinder-Head-Stud-Kit-4-8L-5-7L-6-0l-l92-ls2-Studs-97-03-1997-2003-1998-/191564862260?hash=item2c9a27d334&vxp=mtr
VS
http://www.ebay.com/itm/LS1-LS6-LS2-LS-CHEVY-CYLINDER-HEAD-12-POINT-STUD-KIT-PERFORMANCE-STUDS-/321732992713?hash=item4ae8c7dec9&vxp=mtr
VS
http://www.ebay.com/itm/ARP-234-4110-CYLINDER-HEAD-STUD-KIT-GM-LS1-LS6-4-8L-5-3L-5-7L-6-0L-2003-EARLIER-/161730144216?hash=item25a7de27d8&vxp=mtr
SO make sure that you order the correct year studs/bolts for your car/engine.
My current LS1 in my 2000 FRC just that, 2000 year model LS1. All the stud kits I listed above are for early LS1 engines 97-03.
They should fit.
