Rear clunking sound
NOTE: The Transmission is in Park.
You have never had the brake rotor off the car ast you still have the metal retainers on the studs
The rotor is loose on the hub. Install two lug nuts on the studs and tighten to prevent the rotor from rotating and clanking on the wheel studs. Check for the noise again after you do that.
Its difficult to properly tell in the vid but,,,,,,,,,,, It looks like the LARGE NUT that secures the hub to the output shaft is loose.
NOT GOOD! That could be causing your noise!Clean the RUST off the end of that threaded shaft, soak it in PB Blaster Penetrate. and take the NUT off. Behind that nut is a SPLINED SHAFT that slides into a splined shaft in the HUB.
If that nut is loose, the splined shaft may be worn. I know that the splines need to be properly lubricated and then reassembled and the nut properly TORQUED to... (Rr Drive Shaft Spindle Nut 160 N·m 118 lb ft . ) Same for the left side.
TIA
Yeah, my sway bar bolts weren't even close on the clamps, pretty close on the links though. Everything is checked, and double checked. She'll be rolling with confidence once again thanks to the Forum. Thanks everyone who contributed, and even trolls will learn from this.Chris
