New Swaybars Poll
Old Aug 18, 2002 | 11:13 AM
nevadacoin's Avatar
nevadacoin
Default New Swaybars Poll
I have a 2002 coupe with standard suspension and want to add new swaybars..Please help me out on selecting them... :confused:
Old Aug 18, 2002 | 11:55 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: New Swaybars Poll (nevadacoin)
I have had T1, Z06, and F45 anti sway bars on my C5's. These are my opinions so don't take it personal. The F45 for me sucked! The Z06 are OK. The T1's I thought were great until I jumped in a car with Hotchkis bars. There is no equal to T1's but I got tired of them on the street..but boy they sure keep the tires planted. So I decided to try the BMR's. They are stiffer than the Hotchkis but not as stiff as the T1's. The BMR's are also almost 1/2 the price of T1's and Hotchkis bars. BMR has been making anti swaybars for years for F Body and now are doing C5's. For $340 + some change and an xtra $20 to powder coat any color...I can't see a better bar on the market. I will be trying them out real soon. Thanks Nate!
Here is a list of bars in order of rigidity
T1
BMR
Hotchkis
Z06
Z51
F45/Base
Old Aug 18, 2002 | 08:04 PM
4THTOY's Avatar
4THTOY
Default Re: New Swaybars Poll (Shinobi'sZ)
Where can I get information on the BMR bars? I checked Nate's site and did not find any there. I have a set of Z51 bars now, and was looking for an upgrade
Old Aug 18, 2002 | 08:31 PM
AFVETTE's Avatar
AFVETTE
Best bang for the buck has to be the OEM Z06 bars Ken Ficthner sells for about $230. Changed the character of my car, supple ride yet FLAT cornering. Now I can feel the tires give up way before the suspension/car does.
Tom
USAF Retired
Old Aug 18, 2002 | 08:47 PM
nevadacoin's Avatar
nevadacoin
Default Re: New Swaybars Poll (AFVETTE)
AFVETTE's feedback makes alot of sense to me not being an autocross type of guy, but here is the BMR link..
http://www.lmperformance.com/810/4.html
Old Aug 19, 2002 | 12:14 AM
silversport's Avatar
silversport
I just ordered the Z06 ('02) sway bars for my standard suspension...I heard good things about this set up from a friend...and Tom, you know who you are...it's your fault... :yesnod: :D :eek: :cool: :cheers: :chevy :seeya :flag
Old Aug 19, 2002 | 02:11 AM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
http://forums.corvetteforum.com/zerothread?id=364314
imo- the bmr is your best option. im offering a money back guarantee on the bmr/xtreme bars because i have personally tried all the rest. base,z51, z06, t1 and hotchkis on my ride.
Nate
Old Aug 20, 2002 | 02:37 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: New Swaybars Poll (Nate@xtreme)
hmmmmm :flag
Old Aug 20, 2002 | 07:40 PM
4stroke's Avatar
4stroke
fwiw, I have a set of T1 bars on my 01 ZO6 which I use on the street as well as Texas World Speedway They are signigicantly stiffer than the stock ZO6 bars but the car corners very well on the track which is my main objective. I am usually the only one in the car so the ride quality is not so much an issue however my wife says its a little too stiff except when she is doing laps. I have been told that the complete T1 package will knock your teeth out on the street but the car will corner like its on rails. If you deceide to put the T1 bars on use the Z51 end links or better. I have found that putting some polyethylene ( strips from a coffee can lid works well ) between the bar and the bushings to prevent them from making a popping noise. Good Luck
Old Aug 20, 2002 | 09:34 PM
SvenOdin's Avatar
SvenOdin
I currently have the stock sway bars on my C5, so any of the above would be an improvement!
Waiting for the new sway bar kit from Xtreme to arrive :D
:cheers:
[Modified by SvenOdin, 7:35 PM 8/20/2002]
Old Aug 21, 2002 | 09:34 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: New Swaybars Poll (SvenOdin)
BMR sounds like the ones I'm gonna buy :yesnod:
Old Aug 24, 2002 | 05:18 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
Default Re: New Swaybars Poll (MRWHOOPPEE)
BMR sounds good to me. This could be my next mod.
Nate, I think you have my credit card on file!
Old Aug 25, 2002 | 03:02 PM
Lashtal's Avatar
Lashtal
Default Re: New Swaybars Poll (4stroke)
Teeth? Who needs Teeth when You have a Rocket on Rails! :D
:cheers:
Old Aug 25, 2002 | 04:34 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: New Swaybars Poll (Lashtal)
I think you should upgrade your shocks when you swap swaybars. This will also make a considerable difference.
Old Aug 25, 2002 | 08:27 PM
vettvert's Avatar
vettvert
Default Re: New Swaybars Poll (rschiltz)
I find that with the "base" FE1 suspension setup by changing to the Hotchkiss bars and installing Bilstein Sport shocks front and back, while leaving the stock spring in place, the ride improves 100%. The car rides as if on rail yet is not as jarring for everyday street driving as if I would have changed the springs as well, and I am a vert. Hope this helps.
To New Swaybars Poll
