C6 Z06 rear
Kit includes:
1. 2pcs side cover o-rings
2. 2pcs side cover seals (new C6 design, won't leak like the old style C5 design seals)
3. 1pc C5 rear cover o-ring
4. 1pc Trans to Differential seal
5. 2pcs C6 Z06 diff spider hard gear (left and right)
6. 2pcs diff spider hard gear snap ring
7. 1pc C6 Z06 differential RH shaft
8. 1pc C6 Z06 differential LH shaft
9. 2pcs C6 Diff Hard spring GM part # 7057
10. 2pcs C6 Z06 Carbon clutch pack (Upgrade from the C5 Z06 bronze clutch)
Any buy this kit?
Kit includes:
Any buy this kit?
A LOT of us have completed this modification with great success. Where are you getting this KIT?
I purchase ALL my stuff through Gene Culley (CULTRAG Performance)
Here are a couple of post that you should read that better explains all that involved:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Bill
