clockspring replace
Old Jun 30, 2015 | 05:26 PM
Mattias L's Avatar
Mattias L
Cruising
Default clockspring replace
My Clockspring to airbag was broken
There was no one in stock here in Sweden
So i bought a used one
My question is
Do i have to center it or something so i don't broke it
When i see a video on youtube they sad don't turn it
But i am not sure the earlier owner may have turn it ??
Thanks to all answer
Old Jun 30, 2015 | 08:54 PM
4DRUSH's Avatar
4DRUSH
They break after 3 complete turns in either direction
Only way to turn them 3 turns is disconnecting the steering linkage or by hand out of the car.
Old Jul 1, 2015 | 10:27 AM
dadaroo's Avatar
dadaroo
Would you like me to provide you the actual Factory Service Manual guidance also? Not at home now.
Old Jul 1, 2015 | 03:42 PM
Mattias L's Avatar
Mattias L
Cruising
Ok that would be so nice
And now when i start the car the airbag lamp blink about 3 or maybe 4 times and then it lit all time
is there a spring so when you take clockspring out of the car it will go to center position?
This car is not so easy nut !!
Thanks everyone for help
Old Jul 1, 2015 | 04:05 PM
4DRUSH's Avatar
4DRUSH
As I remember, there is tape on a new clock spring that keeps in centered in the "3 turn range" which you remove before install
I don't know how you would know where the center of the range is on a used one.
Old Jul 1, 2015 | 05:59 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Before you start to remove the air bag 1. disconnect the battery 2. remove the fuse and
relay,, wait about 30 minutes. Make sure the front wheels are straight, remove the
steering wheel,, airbag, then clock spring. Reverse the procedure . I did mine,, hardest part was removing the steering wheel...... there is good info on google also.
Old Jul 1, 2015 | 06:04 PM
mike venth's Avatar
mike venth
mike v
look up "clock spring repair" on the CF search --lots of info
Old Jul 2, 2015 | 07:51 AM
dadaroo's Avatar
dadaroo
Here is some info:
https://www.corvetteforum.com/forums...post1589265877
https://www.corvetteforum.com/forums...ng-help-2.html
Here is the FSM guidance:
You will find 2 PDFs here on the Clockspring.
https://www.dropbox.com/sh/qmqnvsx77...o-H34iCea?dl=0
To clockspring replace
