Manual Gear Shift "Wobble"
Old Jul 5, 2015 | 07:23 PM
rconkin's Avatar
rconkin
Default Manual Gear Shift "Wobble"
I've searched the forum and internet and can't find anything about this. When shifting into 5th or 6th, if I give it gas, the shifter wobbles side to side. More going into 6th than 5th. Is this just how it is, or could something be worn or broken? I only test drove one other C5 and that was last year. I bought my 03 in May and don't remember if the 02 I test drove last year did this. My 03 has 86k miles on it.
Old Jul 5, 2015 | 07:51 PM
bjones7131's Avatar
bjones7131
My 01 doesn't do this, not sure what u mean by giving it gas, is this while u r shifting or after u have it n gear?
Old Jul 5, 2015 | 08:30 PM
rconkin's Avatar
rconkin
When shifting when accelerating. If I just ease on the gas while shifting it only does it a little if any at all.
Old Jul 5, 2015 | 09:03 PM
frsr06's Avatar
frsr06
I fell the same when shifting from 5th to 6th. If I shift with little or no additional throttle it does not happen. I have assumed this is normal but...
Old Jul 5, 2015 | 11:46 PM
brplatz's Avatar
brplatz
Pretty sure it's just the driveline backlash doing a little oscillation at speed. I get it most days too
Old Jul 6, 2015 | 03:13 PM
rconkin's Avatar
rconkin
Thanks, I'll quit worrying about it.
Old Jul 6, 2015 | 06:57 PM
73Corvette's Avatar
73Corvette
I'd take a look at the shifter box and bushings... the bushings get hot and crack... the bolts could have gotten loose on the box also and be letting it have some wobble...I don't think wobble is normal... at least I don't have any.
Old Jul 6, 2015 | 08:01 PM
rconkin's Avatar
rconkin
I'll check those out. It only does it when shifting into 5th or 6th and everything feels tight otherwise. I guess the term oscillates is a better term to use for description of what the shifter is doing.
To Manual Gear Shift "Wobble"
