A/C no cold
Old Jul 6, 2015 | 10:13 AM
gbedigrew's Avatar
gbedigrew
Cruising
Default A/C no cold
I have checked my codes and have non but history. A/C was blowing cold and turned it down a few degrees and it quit. The pressure tested from two differs cheap testers you get to fill system shows pressure in the red. Vents blow air just fine, but no cold. You can hear system kick on when you turn a/c on and off.
Old Jul 6, 2015 | 10:49 AM
dadaroo's Avatar
dadaroo
I hope you know that virtually ALL codes will show H if you pull them after you turn the ignition OFF.
Old Jul 6, 2015 | 12:00 PM
gbedigrew's Avatar
gbedigrew
Cruising
The code it showed is B0367
Old Jul 6, 2015 | 01:19 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
B0367 Right Actuator Feedback Open --here is a starting place, hope it helps
Old Jul 6, 2015 | 04:32 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
I'd be worried if the refrigerant is in the red. you might be icing things up and that could be very bad
Old Jul 18, 2015 | 09:24 AM
dadaroo's Avatar
dadaroo
Where are we at this? Was the code a true H?
Do you have A/C high and low side pressures? You can't test the system with those cheap testers. Would never try to add refrigerant using one either. The C5 needs a very specific amount to work.
To A/C no cold
