Input shaft hosed???
So the story begins with hearing a horrible sound coming from the clutch area. Did some looking on here and the consensus was that the pilot bearing is screwed.
So I ripped it all apart and found that this is true. There were two needles left in "one piece" but they were flying all over. I think that some or one got wedged between the input and the pilot bearing housing and created these scars shown in the pics.
It also looks like maybe it was heating up the input a little much and then the splines where the clutch goes might have twisted or flattened them.
What are you guys thoughts? Replace? If so where can I get one fairly inexpensive? 12 mm one.
Also the much debated bushing or bearing to replace the hosed pilot?
Thoughts?
My shaft is supposedly a solid setup with billet couplers. Was told the runout was .003. Don't have a dial indicator to verify it though.
Do you folks think that I am ok with still running the solid setup? Or should I run a rubber front?
Also my power currently is around 500 to the wheels with intentions on going to the 700 down the road so...
You guys help is appreciated.
Robert
