AC issue
Old Jul 6, 2015 | 08:52 PM
Vett4MVZ's Avatar
Vett4MVZ
Default AC issue
2000 coupe
Yesterday AC was blowing niceand cold.Today blowing warm. Ran codes on DIC, New code in PCM P0161 H.
Any clue as to whats going on?
MVZ
Old Jul 6, 2015 | 09:31 PM
Vett4MVZ's Avatar
Vett4MVZ
Old Jul 7, 2015 | 09:30 AM
dadaroo's Avatar
dadaroo
Try this:
Re-Calibrating Actuators
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module (fuse #27) in the passenger fuse box.
Important
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
This procedure reset the HVAC unit and must be done exactly as posted.
Old Jul 8, 2015 | 01:08 AM
BigGun's Avatar
BigGun
If no hvac codes your actuators should be working correctly. Is the compressor coming on and are both sides hot or just driver side?
Old Jul 8, 2015 | 01:38 AM
Vett4MVZ's Avatar
Vett4MVZ
Went back to shop that charged system 3 months ago. After checking and finding no leaks he was able to put more freon into system.Took a while to get a whole can in but when done both sides were blowing cold.
Thanks for the input and replies
MVZ
To AC issue
