stock headers with p0420 code
Old Jul 7, 2015 | 12:48 PM
02Zvert06's Avatar
02Zvert06
Default stock headers with p0420 code
i had the p0410 code and got that fixed then the p0420 code came up ive reset it multiple times and it keeps coming back. i live in nova and need to pass emissions asap. ive read and searched but most of what i have found was for LT headers.. i do have a borla axle back exhaust. so im looking to replace the 02 sensors first but can not find the correct (rear) 02's any help here? i guess after i replace that and it throws the code again ill have to buy a stock h pipe?
any help will be much appreciated..
Thanks!
Old Jul 7, 2015 | 02:17 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
13111 is the o2 sensor part number
Just replaced mine.
Old Jul 7, 2015 | 02:37 PM
02Zvert06's Avatar
02Zvert06
Just replaced mine.
did it solve your problem? im really hoping i wont have to replace cats
Old Jul 7, 2015 | 10:06 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
not this go around. back when i had the P0430 (passenger cat) it did.
Old Jul 8, 2015 | 10:25 AM
02Zvert06's Avatar
02Zvert06
so are you going to buy the stock h pipe used with cats?
Old Jul 8, 2015 | 01:45 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
The car has bbk headers with aftermarket cats. Will need to buy those again.
Old Jul 8, 2015 | 03:19 PM
skip1980's Avatar
skip1980
p0420 is for a catalytic converter efficiency code. The converter is not cleaning up the exhaust enough and is setting the code. I have never seen replacing o2 sensors fix this code. Going to have to replace the converter.
Old Jul 8, 2015 | 04:23 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
I have because I've done it. Looked at the sensors through a scanner. The passenger rear o2 wasn't switching. When my drivers side p0420 code came up i replaced the sensor without checking.
Old Jul 9, 2015 | 05:27 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Did some diagnosing today. hooked up the scanner. The drivers o2 sensor was real lazy and stuck at 0mv at idle and cruise. Would react only if i accelerated. Replaced with another one. Code has not come back.
Old Jul 13, 2015 | 11:59 AM
02Zvert06's Avatar
02Zvert06
ok another question, so i have the stock cats with "pup" cats... i have a 2002 so i will need the stock mid section from a 2001+... but the Z06 does NOT have the pup cats. will this affect emissions testing on my car in NOVA? i need to pass emissions ASAP
Old Jul 14, 2015 | 10:27 AM
02Zvert06's Avatar
02Zvert06
well believe it or not, i installed a new o2 sensor, drove it for about 100 miles and passed emissions!!!!
Old Jul 14, 2015 | 02:25 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Glad it worked out.
Old Jul 14, 2015 | 03:50 PM
02Zvert06's Avatar
02Zvert06
Well the code actually came back on but I passed emissions. So I have 2 years to fix it. Might go with headers by then
To stock headers with p0420 code
