Weird oil pressure issue
On my way back, I was cruising on the Interstate when I notice my coolant temp starting to rise.
Pull over, top off the fluid (which was about half a gallon low) and continue
Ten minutes later, the dash lights up, LOW OIL PRESSURE
I start to pull over, and then bam the coolant over heats again
I shut the motor off and coast into a gas station
Coolant level is fine. Oil level is fine. No milky oil, nothing
I decide to start the car once it cools off, and still no oil pressure
But no weird noises. No ticking. No bearings shredding themselves to pieces. I rev the motor and it builds pressure to 25 PSI at 2500rpm
I decide to drive it home rather than spend $300 on a tow truck
Car does fine on the way home (all highway) and when I pull into the shop, I let the car idle and of course, 2 PSI oil
I changed the oil and there's no metal shavings or metallic glitter in the oil. I put in 20w50 to see if I can get some better pressure
With the 20w50 I get 10psi on idle and 40psi at 2500rpm
The gauge doesn't fluctuate and it's not erratic, so I don't think the sender is bad. There's no strange ticking noises or anything horrid out of the motor. I pulled the valve covers and no broken springs. I decided to take a drive, and the car doesn't miss or seem down on power.
If there truly was no oil pressure, wouldn't I be hearing my motor tearing itself apart??
The only thing I haven't done is check the oil pressure with a mechanical gauge, which is my next step. I've just been avoiding it because it doesn't look like much fun
Thoughts? Suggestions? What else should I check?
Thanks!!!
Changed oil AND filter*
The OPS doesn't make and erratic movements and it doesn't suddenly go from high to low at all
It's very smooth reading. It only reads low at idle, and even then it's still 10 psi
When I rev the motor, it climbs smooth to 40ish
