Fuel level sender
Old Jul 8, 2015 | 05:10 PM
NukeC5's Avatar
NukeC5
Default Fuel level sender
I just installed the LPE fuel pump kit and a Racetronix wire kit to provide ample volume for my nitrous kit. After I got it back together and was obviously empty on fuel, the sender read at 3/4 tank and stayed the same after putting $20 in the tank.
I was careful with the install and I don't think I damaged the sender, but it's possible. Has anyone had this happen? I am leaning towards the float and rod being stuck on the filter or something. Either way I have to tear it back apart .
I'm debating ordering a new sender kit so I don't have to go back in twice. Id' hate to drain it again and fiddle with it to no avail. Might be better to just put a new one in. Of course I'd rather save the money if it isn't likely damaged.
Old Jul 8, 2015 | 06:58 PM
cmiller8006's Avatar
cmiller8006
Something might be stuck on the float. I found out I had the jet siphon tube catch mine when. I did the eliminator pump and wouldn't read at all.
Old Jul 10, 2015 | 06:45 AM
Chicago1's Avatar
Chicago1
emptying the gas is easy just jump the fuel pump relay and either pop the cap off the rail or throw a fuel hose over the feed and let it drain into a bucket. You can have a beer while its pumping the fuel out
Old Jul 10, 2015 | 07:26 PM
NukeC5's Avatar
NukeC5
Thanks for the input guys. I'll check it out when I have the time again. Might be a month or so.
Old Jul 11, 2015 | 12:22 PM
RXPX's Avatar
RXPX
Please do report back what you find, if you don't mind. My car is having problems with fuel level display also.
Thanks and good luck!
Old Jul 11, 2015 | 01:21 PM
Chicago1's Avatar
Chicago1
start a thread so folks can help you out. Sorry if I had missed it
Old Jul 12, 2015 | 03:10 PM
NukeC5's Avatar
NukeC5
Ok I figured it out. The rod was just stuck on the plastic fuel tube. Just adjusted it out of the way and now the sender has a full range of motion. Easy fix.
Old Jul 12, 2015 | 05:11 PM
Chicago1's Avatar
Chicago1
So you got your rod working correctly. that a boy
Old Jul 12, 2015 | 06:26 PM
RXPX's Avatar
RXPX
Yes sir, I'll post a thread up soon. Thanks!
Awesome! Glad you got it figured out man, frustrating to be left stranded on the road.
To Fuel level sender
