Fan switch
Old Jul 9, 2015 | 09:33 PM
flashg8's Avatar
flashg8
Default Fan switch
When I turn on my fan switch it will only work on #5, wide open or nothing. 1-4 settings won't produce anything more than a trickle of air. Is it just the fan switch or is the fan motor going bad?
Old Jul 10, 2015 | 10:27 AM
flashg8's Avatar
flashg8
2000 FRC. It is a manual controlled ****. With 5 settings.
Old Jul 10, 2015 | 10:42 AM
dadaroo's Avatar
dadaroo
And if you look at Post 59 you will see that high speed (5th position) goes around (not thru) the resistor bank to put the motor into high speed.
Old Jul 15, 2015 | 09:53 PM
flashg8's Avatar
flashg8
Thanks guys! I changed out the controller today & it's fixed
To Fan switch
