wipers
Old Jul 12, 2015 | 12:03 PM
jeffieg's Avatar
jeffieg
Default wipers
hi
my wipers only work turned to hi but only run med. speed and do not park at all. when turned off they stop where they are at. is this the motor? thanks for any help
Old Jul 12, 2015 | 01:04 PM
SPEED750's Avatar
SPEED750
Chances are your wiper motor is sitting in a pool of water due to clogged drains. Do a quick search on here and you will find the write up on how to pull it. That's how I fixed mine. Sometimes you can open up the circuit board and let it dry out, sometimes it needs to be replaced. I left the rubber "udders" out after I fixed mine to ensure no more drain issues.
Old Jul 19, 2015 | 10:15 AM
jeffieg's Avatar
jeffieg
Originally Posted by 8VETTE7
Likely the motor and the electronics that control it is or has sat in a pool of water due to blocked rubber udders preventing the wiper wells from draining:
http://forums.corvetteforum.com/c5-t...ak-checks.html
Check the wiper wells on BOTH sides of the car.....
cleaned udders and replaced motor board and now working in all modes but still need to cal. but back is out so will reply back when I get well to do that thanks for all your help guys
To wipers
