Alignment
Old Jul 16, 2015 | 02:15 PM
NoahGW's Avatar
NoahGW
Default Alignment
Lowered car on stock bolts 1.5 inch, getting alignment Monday. Should I stick with factory alignment or something more aggressive? It's my daily driver, will be taken to drag strip rarely, 2002 Mn6 Z51 coupe.
Old Jul 16, 2015 | 05:55 PM
Bill Dearborn's Avatar
Bill Dearborn
GM only recommended dropping the cars 15 mm on the stock bolts. That kept the stock shocks from bottoming out on severe bumps.
If you aren't doing any autocrossing or taking the car to a road course you should go with the Pfadt street settings. Huge amounts of camber won't do a thing for you on the street or strip and you may not push the car hard enough to tell how much better the car turns with an aggressive alignment. Most street/strip drivers have little idea how hard a car can be pushed in a corner.
Bill
Old Jul 16, 2015 | 07:09 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
if you want the best tire wear for everyday driving, then stay with stock. considering you are drag racing it, no need for more negative camber.
Old Jul 17, 2015 | 12:46 AM
SG Lou's Avatar
SG Lou
Factory settings
Old Jul 17, 2015 | 08:39 AM
NoahGW's Avatar
NoahGW
Thanks guys!
To Alignment
