Mirror Replacement
Old Jul 18, 2015 | 03:54 PM
SpeedConvert's Avatar
SpeedConvert
Navigator
Default Mirror Replacement
My driver's side auto dimming mirror is delaminating. i was going to try and replace the mirror glass myself, but while at the dealer having headlight problems diagnosed, I asked them what they would charge.
I purchased the C5 nearly 3yrs ago with a 3yr-extended warranty, so why not get everything taken care of before it expires? But I want to know if the dealer is honest.
They came back with a quote of $950 ... But did not mention to me that it is for the entire mirror -- new glass inside a newly painted housing. They never mentioned the option of simply replacing the glass.
If I did not have the extended warranty, which approved the $950 mirror replacement by the way, I would have looked for a way to do it my self.
So? Is it possible to even do?
Old Jul 19, 2015 | 07:31 AM
tentuna's Avatar
tentuna
The mirror is ~$200 (i'm sure there are GM dealers on the forum) and easily replaced, just be careful not to break the new one when pushing it back onto the pins, I did mine and it came out fine. Why he wants to replace the mirror housing is beyond me, sounds like bill bloating.
Old Jul 19, 2015 | 09:24 AM
dadaroo's Avatar
dadaroo
Here is how to replace just the glass and plastic surround. You can get the non dimming with heater for about $100 for several vendors like Corvette Central. That is where I got mine and here is how to replace it.
This guidance is for removing just the mirror insert (with plastic surround) in cases where the actual mirror has an issue or you need to access the motor assembly behind it.
The mirror housing can be left attached to the door.
Before you start, place a blanket under the door so if you drop the mirror it will not break and if any of the positioner pins come out they will not be hard to find, There are 4 of them.
Move the mirror all the way up or down so you can get your fingers behind the mirror.
Placing some tape around the housing edges before you start so as to not scratch the housing paint would be a good idea.
The mirror connects to the motor assembly with 5 snap in connections.
One is the main pivot ball in the center, The other 4 are smaller with one above, below, left, and right of the large center pivot.
The 4 smaller ones are driven by the motor assembly to position the mirror.
Have a friend hold the mirror housing while you pull on the mirror insert.
The mirror insert should “pop” out and be released.
Note: Now you will have to remove the heated mirror wiring connector and if equipped, the connector for the auto dimming.
One or more of the position pins may come out with the mirror insert or just fall on the ground. This is OK and not an issue.
If any pins come out they should have a spring attached to them so don’t lose the springs. The pins actually are inserted into the springs.
When I removed my mirror insert one pin came out with the spring still attached to the mirror insert. I simply removed it from the mirror insert just reinserted it into the motor assembly before I put the mirror insert back on. Everything worked just fine after I finished.
The mirror insert has “cupped” like connectors that the pivot and pins fit/snap into.
Use a good silicone type lubricant on the pins, pivot, and mirror insert connectors to make reattaching the mirror insert easier.
Please note the 4 pins have a small protrusion that has to be aligned correctly to match the mirror insert connectors . Not hard to “eyeball” the correct alignment but if not close the insert will not snap back onto the pins.
You should now be ready to reinstall the mirror insert.
Reattach the one or two wiring connectors.
If your new mirror does not have the electrochromatic feature (and the original did) just tape the wires off and make sure they are stuffed back so they don't interfere with the mirror motion. It will be apparent which wires are for the heating element versus the auto dimming.
Have a friend support the housing so it does not move when you press the mirror insert back in.
I recommend (must do or similar) cut a block of wood to cover as much of the mirror as possible so when you press in back on so you distribute the pressure and don’t break the mirror. Also place a small towel or soft material between the block and the mirror so as to not scratch the mirror.
As you start pressing the mirror insert in, try to put move the mirror insert and motor assembly so it is not tilted like you did when you removed it. You want all the pins and pivot to snap in at one time.
It takes a good amount of pressure to snap the mirror insert into place. That is why you need a friend to hold the housing and you need to lubricate the pins/pivot and the mirror insert connectors.
If it does not snap in with “reasonable force”, remove the mirror and double check the alignment of the 4 pins. I found out that I had not correctly aligned them all and had to redo that and then it snapped in.
When I reinstalled my insert I did not have a friend to help so I had to press with one hand while I held the housing with the other. It takes good amount of pressure to snap it in but I did it with one hand.
Good luck.
PS:
Remember if you are replacing the motor assembly there are 2 types. One with Memory and one without. The one with Memory has 2 connectors, not one. The one with memory has an additional 4 pin connector.
Also, you can see what the inside of the housing looks like in this link. Look at Post 5.
https://www.corvetteforum.com/forums...post1589124524
Mr. Sam
Old Jul 19, 2015 | 09:31 AM
73Corvette's Avatar
73Corvette
Nice write up Sam...
Old Jul 19, 2015 | 07:44 PM
SpeedConvert
Navigator
Default Motor Bad Too!
I forgot that the motor was going bad too. I hope the dealer remembered that. The mirror slowly raises over the course of a week.
So now add that to the mix. You probably would just order a new case with a motor already in it, right?
And thanks for the instructions Mr. Sam. I should have written you guys first.
Old Jul 20, 2015 | 06:17 AM
dadaroo's Avatar
dadaroo
You could order a whole new assembly and just put the guts in the existing painted housing. The housing could stay attached to the door.
You would just need to unplug the connector in the door. Here is how to get the door panel off.
http://www.vetteessentials.com/instr...or_handle.html
To Mirror Replacement
