big tire questions
Old Jul 20, 2015 | 11:39 PM
fasttoney's Avatar
fasttoney
Default big tire questions
Hello all,
I have some sp20 ccw rear wheels. The rim size is 20x13. And im currently running the 345/25/20 nitto invo tires. I want to get some drag radials, but dont want to buy new smaller rims. If i go with 20 inch drag radials, ill be losing meat to the ground. My question is : has anyone ran 20 inch drag radials? If so, by who, and what size? Or do i just break down and buy some 13x18, and be done? Any and all info is appreciated. Thanks all.
Old Jul 21, 2015 | 04:38 PM
TwinTurboZ51's Avatar
TwinTurboZ51
The problem with 20" rims is that even if you put on drag radials there isnt any sidewall. Then of course they weigh a ton comp[ared to smaller rim sizes.
I have a set of 19/20 TSW rims but have the OEM wheels still as well and run 18" Nitto NT05R drag radials on those. They work so well I just broke my output shaft at the dragstrip.
Old Jul 21, 2015 | 09:00 PM
fasttoney's Avatar
fasttoney
Thanks twin turbo. I have a twin turbo as well. i figured. Guess i have to get new rims. Guess this is a good time to get some black wheels as well. Thanks again
Old Jul 22, 2015 | 12:25 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Drag racing usually requires the largest sidewall as can fit----A 20" wheel will be so stiff and may work great on a road course but as a drag car you will get "0" wrinkle affect at launch--- My best runs on my C5 were done using C4 16" wheels---The sidewalls were incredibly like 5" and the car would bite like crazy with 12 PSI of air in them---
My 98 car with approx. 400 RWHP would run consistent 12.1's and 1.7--1.8 60 ft times
Old Jul 22, 2015 | 05:29 AM
fasttoney's Avatar
fasttoney
Those are nice numbers tblu92. I got big brakes, and wide fenders. Couldn't got to 16 inch. But thanks for the info
Old Jul 22, 2015 | 09:20 AM
4DRUSH's Avatar
4DRUSH
Get some C6Z06 rims & run 325 DR's
Old Jul 22, 2015 | 10:28 AM
fasttoney's Avatar
fasttoney
Thanks 4drush.
Old Jul 23, 2015 | 04:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out this post for better output shafts on the cheep!!! Good for ANYONE who wants better traction without busted output shafts!
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Old Jul 23, 2015 | 04:37 PM
fasttoney's Avatar
fasttoney
Hello. Bill C. The man, the legend, the myth. Thanks for chiming in. Its an honor. Oh, and thanks for the info.
Old Jul 23, 2015 | 04:40 PM
fasttoney's Avatar
fasttoney
The trans and rear was done by rpm. They have rpm tags on them both. It was done by the previous owner. I will look into it, to see exactly what was do e to them.
To big tire questions
