Why would a differential leak?
Old Aug 20, 2002 | 12:14 PM
Untouchable00's Avatar
Untouchable00
Default Why would a differential leak?
Mine is doing that now. Is it because its improperly mounted or that it is defective? It's a brand new 3.42 Getrag.
[Modified by Untouchable00, 11:14 AM 8/20/2002]
Old Aug 20, 2002 | 12:22 PM
2001 Red Coupe Bandit's Avatar
Default Re: Why would a differential leak? (Untouchable00)
I know of your story. That stinks. :confused:
Well, just like any part on the planet or any product made, they all can't be 100% perfect and some will always have an isolated problem. You might just got unlucky.
Now maybe someone with experience will chime in and tell you to look for something that might allow you to fix it, like a seal or something?
I hope you get it worked out as I know it is stressful to have your car not working while in the middle of a mod. What is teh Tech saying to do?
Good Luck B....
The Bandit...........
Old Aug 20, 2002 | 12:32 PM
Untouchable00
Default Re: Why would a differential leak? (2001 Red Coupe Bandit)
I wish the tech would call me. I have only talked to the secretary and its been with them for 10 days. I don't want to bother anyone, but I am very conerned about my car. I don't want it sealed, I want all brand new parts.
How long do heads/cam and superchargers take?? I am only installing gears, TC, transgo and tranny cooler. I know the tech has some family issues, but I am just wondering how long this really should take.
Old Aug 20, 2002 | 01:07 PM
MitchAlsup's Avatar
MitchAlsup
The reason that a differential leaks is that the process of taking the engine torque multiplied by the transmission ratio and multiplying again by the rear end ratio causes large forces to exist a) at the teeth of the gears, and on the bearings holding the gears on axis. It is the bearings that hold the gears on axis that transmit these large forces to the differential cases. The cases are not strong enough to put up with a) incresed engine performance, b) sticky tires, c) sticky launch areas on drag strips,...
Old Aug 20, 2002 | 01:13 PM
Untouchable00
Default Re: Why would a differential leak? (MitchAlsup)
Well, the car has yet to be driven since the install. It began leaking before it was even started. And that email was like my high school chemistry teacher talking to me. English, please :lol:
anyone, anyone, something ooodooo economics, ooodoo economics, voodoo economics.
Old Aug 20, 2002 | 01:18 PM
Mike Mercury's Avatar
Mike Mercury
Did you transfer over the seal plate from the existing carrier (or install a new one) onto the 3.42?
[Modified by Mike Mercury, 12:20 PM 8/20/2002]
To Why would a differential leak?
