1998 A4 transmission fill plug
Old Aug 3, 2015 | 07:04 PM
robert1989's Avatar
robert1989
Default 1998 A4 transmission fill plug
Hey, I stripped out the fill plug on my transmission.
So I ordered a new one I'm guessing I ordered the wrong part number.
The GM part number I got is 24233099 (ACD is the same)
I'm looking at this thing thinking no way the plug on my pan is like 23-24mm this is about 12mm.
Anyone know the right part number?
Old Aug 4, 2015 | 04:02 PM
robert1989's Avatar
robert1989
Since I can't figure it out I'm assuming you can't get this part separate so I ordered a new pan. Just a normal "deep" pan non stock. It is 3 and 5/8 inches deep while the stock one is 4 inches (at the deepest part). The one I ordered comes with a drain plug but no fill plug so I ordered a "drain plug" which I plan on putting in the same location as the fill plug. I'm under the impression that I will have more fluid it the new pan than the old one. Considering it has a constant volume all around oppose to a small section that happens to be a little deeper.
What say yee?
