C5 Foglight option
Found another SUPER BRIGHT led fog option for pitted stock lenses and poor throw and these have replaceable lenses! They use a 9 led COB and as I'm writing this, I can barely see the screen after being flashed for only a brief second from the side of these lights. They only cost 24.00 for the pair..but see for yourself the intensity of the light. I had HID in my stock units at 6k I have to say these are actually almost too bright and a whole lot brighter then 24W Hid. in fact they may be too bright to use with oncomming traffic unless they are leveled down far or smoked would blend in nicely!
Picture one - The assembly Pre-Modification (bracket must be made)
Picture Two - Unscrewed showing lens
Picture Three - Side view in operation - Seriously this blinded me
Picture Four - A room that is lit by a 100w lamp, so bright it throws the camera white balance for a loop. Thermally they operate slightly warm, but at 1 inch from focus, your hand will feel the intensity of the COB.
Purchased on Fleebay keywords COB DRL FOG
Can the LED module be added to the stock Fog Light housing?? How did you make the brackets?
Jay
Jay
All work is done from Topside, unless you're a 1%er like myself and drop your 1/4 drive wrench down the shoot.
The removal is straight forward, Turn on the headlights and disconnect the Negative Battery cable, leaving the lights in the UP position. Using a 1/4 drive socket wrench preferably a stubby with swivel head, remove the single 10MM bolt holding the factory fogs in place, they are located directly under the headlights accessed on both sides from the middle of the car, and will fit a size large forearm without problems. Remove the electrical connector, and bring the fog out between the headlight and the hood hinge. Careful not to scratch your covers.
Prepare the factory bracket by unscrewing both phillips screws securing the factory fogs to the OEM bracket, Here is the good news, The bracket can be used AS-IS with NO MODIFICATIONS! and is right on the money in placement of the lenses! Believe it or not, these were eyeballed from an ebay photo, I took a chance on the size being close to stock, I was 3/8s of an inch off but the flip side was the slightly smaller diameter eliminates all the issues with the fogs hitting the plastic panel, a complaint I have read over and over regarding aiming. I opted to NOT use the factory adjusters and keep my units in a fixed position, I was pressed for time and the extra work would have been very easy, you need a slightly longer bolt, 2 washers two small nuts and a small spring, all in all about 2.00 at home depot/lowes and you will retain the ability to aim the units just like factory!
Notes : If you experience dim performance during testing, and this threw me off for 35 mins, check your Ground Pack located on the pass side directly behind the headlights on the frame, I had worked mine over, used ACF-50 and all and still had an issue 2 years later so I re-cleaned them, you may find the same problem and grease dont matter, its still a crappy ground point.
Heres some shots of the mod, I have not linked the actual units I purchased unless all agree to a URL post to ebay since I am not supporting any one person, but a PM is fine if you wish to have the sellers name.
On to the photos.
in for the information
