Rear 02' Oxygen Sensor Part # Needed
Old Aug 6, 2015 | 02:35 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Default Rear 02' Oxygen Sensor Part # Needed
Planning on installing my LG SP headers this weekend. Gonna hold off on the rest of the mods(heads/cam/clutch) til I get into a new house.
It's my understanding that with the LG headers, you use the rear sensors in the front position. I figure I should just go ahead and install new sensors with the headers. I will keep the original rear sensors in the rear location. I am deleting the Air injection system so I know my check engine light will be on due to that. Hoping a tuner won't charge me too much to get rid of that.
Can someone please post what sensors I should order. Plan to order off Amazon so I get them Sat. Thanks
Old Aug 7, 2015 | 12:46 AM
StingrayRebel's Avatar
StingrayRebel
I just ordered some from amazon about a week ago just to replace them due to age... ac delco # 213-810
Old Aug 7, 2015 | 02:19 AM
IRON MAIDEN
Thanks. RIP RRP!
Old Aug 7, 2015 | 02:21 AM
IRON MAIDEN
Weird. It say's it does not fit my 97' C5???
Old Aug 7, 2015 | 02:37 AM
StingrayRebel
hmm, I'm not sure about that one, I have an 02
Old Aug 7, 2015 | 02:03 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
look them up on rockauto, might get the part # then go back to Amazon with some part numbers
mike
Old Aug 7, 2015 | 02:21 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Rears have different plug connector than the front. Front are 4 pin inline. The rear are 4 pin in a square
Old Aug 7, 2015 | 02:39 PM
StingrayRebel
is this just on older c5's?... all of mine are square plug but I'm only using the fronts currently... years ago when I installed my headers I just swapped the rears into the front plugs and have never had any issues... I just bought new ones for the heck of it, after 13 years I'm sure new ones can't hurt
Old Aug 7, 2015 | 04:20 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Well my 2000 has the two types. Just looked up a 97 and shows two different connectors.
Old Aug 9, 2015 | 12:55 AM
IRON MAIDEN
LG sent me the adapters to use the rears in the front locations. I just turned 70K on my 97' so figure I should go ahead and replace them while I'm there.
To Rear 02' Oxygen Sensor Part # Needed
