Headers, Long Vs. Short
Old Aug 21, 2002 | 12:27 PM
connellyh's Avatar
connellyh
Default Headers, Long Vs. Short
Time to open up the worm can again...
Is the cost of long tubes really worth it? I've been an advocate of long tubes for a long time, but I've heard calims that the newest B&B shorties are just as good. Thoughts? Comparissions?
Old Aug 21, 2002 | 12:43 PM
Miles in Michigan's Avatar
Miles in Michigan
Default Re: Headers, Long Vs. Short (connellyh)
Claims from who? Did they include before and after dyno graphs?
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Long tubes will give you a better torque curve.
Old Aug 21, 2002 | 12:46 PM
Mark VerMurlen's Avatar
Mark VerMurlen
From what I've seen, the shorties cost the same or more than some of the long tubes. So I haven't really given shorties much thought. The (only?) advantage of shorties is that they bolt up in place of the OEM manifolds so they should be easier to install. I'm planning to go with long tube headers when my mod budget will allow it.
- Mark
Old Aug 21, 2002 | 12:50 PM
MitchAlsup's Avatar
MitchAlsup
Shortie headers are simply more efficient version of exhaust manifolds. expect 5-7 HP and/or Tq
Long tube headers are both more efficient versions of exhaust manifolds, but MOR IMPORTANTLY, these headers extract latent energy from the high pressure exhaust pulse and utilize this energy to inhale more mixture. More mixture in->more power out, bigger exhaust pulse->more mixture in. expect 15-25 HP and Tq.
Old Aug 21, 2002 | 02:37 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
http://www.vetteguru.com/mods/headers/
Old Aug 21, 2002 | 03:19 PM
RHILL's Avatar
RHILL
Default Re: Headers, Long Vs. Short (MitchAlsup)
Mitch hit the nail on the head :cheers: ...... save your money and buy long tubes
Old Aug 21, 2002 | 03:35 PM
thefly's Avatar
thefly
i agree with everyone else on the performance of long tubes, however, one thing you need to consider is the year of your car. if you have a 2001 or newer coupe or convertible you will be breaking the law by installing long tubes. no the cops are going to show up at your door but you can't legally tamper with the emissions equipment and replacement with non oem equipment till 50k, i think. which is why some people prefer shorties in those situations. i also forgot 2001 Z06's, and all california emission car would fall under this. the reason is because with long tubes the pre-cats are eliminated on these models. all 2002 and up Z06's don't have them to my knowledge...
Old Aug 21, 2002 | 03:38 PM
kewlbrz's Avatar
kewlbrz
Default Re: Headers, Long Vs. Short (thefly)
good point thefly. btw, 2002 ls1's still have pre-cats.
Old Aug 21, 2002 | 04:08 PM
thefly's Avatar
thefly
thanks dude, for pointing that out sorry i thought i worded that clearly, i guess not, even i was confused after reading it again.
Old Aug 21, 2002 | 06:23 PM
ledfoot's Avatar
ledfoot
Be a Man...GO LONG! :D
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Lowered/Yokohama Avs Sports/Porsche DOT4 Hi-Performance Brake fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
To Headers, Long Vs. Short
