Randomly get P0300 codes.
Old Aug 19, 2015 | 05:04 PM
vettewheels123's Avatar
vettewheels123
4th Gear
Default Randomly get P0300 codes.
2002 C5 Z06 here.
Just went for a quick drive around town for 10 minutes. I saw I had a check engine light about 5 minutes into the drive. When I looked at the onboard code reader it gave a PCM P0300 pending which is random misfire.
I had this happen to me a few weeks ago, so I changed the plugs to TR6 and gapped them at .041. Wires look OK. Happens very seldomly and definitely only once every few days, it does not return when cleared.
Any ideas what would cause this? Car is cammed and is running perfectly otherwise.
Old Aug 19, 2015 | 07:45 PM
ssrallyred's Avatar
ssrallyred
Originally Posted by vettewheels123
2002 C5 Z06 here.
Has it been tuned after the cam install? If so did the tuner change the threshold on when the P0300 is triggered ? A miss fire is usually triggered by the crank sensor and a cam with even just a little more duration etc. will set that code.
Old Aug 19, 2015 | 10:29 PM
StingrayRebel's Avatar
StingrayRebel
this is very possible, my car did the same thing after the cam install until I had it tuned... since the plugs and wires are good, take a look at the coil/injector harness on the driver side where it runs behind the intake... there is a useless bracket near the back of the fuel rail and the harness is prone to rubbing on that bracket and over time can eventually damage the wiring and give you all sorts of problems... I removed that bracket the first time I took my intake off
Old Aug 20, 2015 | 01:06 AM
vettewheels123
4th Gear
The car is tuned. Is there something my tuner might have missed? Doesn't seem like he gets many cars back for this. I'm on EFI Live.
I'll check out the bracket but I'm pretty sure nothing has rubbed through any wires.
Old Aug 21, 2015 | 11:46 PM
vettewheels123
4th Gear
Happened today again, guys. Any ideas? How can I pull logs? My OBDII bluetooth phone scanner doesnt see anything except the code.
To Randomly get P0300 codes.
