Radiator life expectancy
Background,
Car: 2004 C5 with T6 manual transmissions
Modifications:
STS twin Trubo
(first after market heavy duty radiator installed as part of setup in 2001)
GT2 Adjustable Coilovers, (installed 2000 miles ago)
West Coast Corvette Street/Race sway bars
DeWitt Spal duel fans
Electric Water Pump
Several other mods that don't come in to play here
Issue, I seem to be replacing my radiator as often as I change oil
. In the last four years, (I drive the car about 3000 miles per year) I have had to either have the radiator repaired or replaced due to failure of the welds of the tubes into the side tanks. Since this started prior to the coilover installation I'm inclined not to point the finger there however it has started since the "upgraded" radiator that was installed at the same time as turbo kit. I have just ordered my 3rd new radiator, this time A DeWitts, but would like to know if there are any tricks out there to better mount/secure the radiator to help prevent this type of failure? I need the extra cooling capabilities of the aftermarket radiator so going back to factory is not an option as the car would run hot with the turbos, which is why I added the upgraded fans and water pump to help address that issue even with the larger volume.
Background,
Modifications:
STS twin Trubo
Electric Water Pump
Bill
Bill
I'm using the pink stuff GM Dex-Cool ® Compatible coolant
If the problem is structural you'll need to make sure that radiator is not tweaked when installed and the hoses line up and are not stressing the connectors on the radiator. Does the radiator have plastic tanks and/or connectors? If so make sure that you are not using generic auto parts store worm drive hose clamps because they can create a pressure point under the worm drive assembly that can crack the hose neck and/or tank.
I see we are both South OC
, I'm in MV if you would like to view the current work in progress (radiator out waiting on the new one) PM me and I'll give you my address and number.
I found them on EBay and this is there website: http://www.speedcooling.com/Radiator...r/prod_41.html
Looks like the Dewitt Radiator but half the price $249
I have a 1998 C5 Automatic with a 383 ERL Stroker at 11 to 1 compression; aftermarket LS6 Heads, Cam, Level 4 transmission, upgraded gears, cold air, headers, x-pipe, z06 exhaust, upgraded tork tube bushings, 200 amp alternator, Dewitt Radiator Fans, 103mm Intake Manifold, 103mm Throttle Body, Cold Air Intake and a few other items... Last time I put it on the Dyno with a sleeper cam (prior to upgrading the cam and oil blow by...) I made 448 RWH / 440 T...
I expect I am going to get something like 466-470 RWH 455-465 T on the next Dyno pull since the blow by is gone and the Cam is much more aggressive...
The following is the Product Information:
This is our HD aluminum radiator for the 1997 - 2004 C5 Corvette with a 6 speed manual transmission and 1997 - 2000 Corvettes with automatic transmission. This will not fit the 2001 - 2004 Corvettes that use the quick disconnect transmission cooler line fittings. This radiator features:
- All aluminum construction with a heavy duty 2-row core with 1.0" tubes with a high density core that has a higher density core than other high performance radiators costing 3 times as much!
- Heavy duty transmission cooler for automatic applications
- Fully TIG welded construction with no epoxy.
- Upper hose and lower connection is 1-5/16".
- Overall dimensions are 28" wide x 18-7/8" tall. Core is 24-3/4" wide x 17-3/8" high.
Given the fact I'm on my third radiator at this point. I'll take the DeWitts life time warranty.
Thanks for your response!
Roger
Updated: just checked he carries a lifetime warranty and thus hopefully I won't have to use it...
Good to know that you are getting a warranty. I did not get the receipt so could not prove it was their radiator just what was on my work order from the shop. With the DeWitts I have the receipt so in the future I have the proof.
Now viewing DeWitts website they recommend that you change coolant every three years and not a specific type. I will stay with G-05.
