Z06 bluetooth phone integration installation
1. COR-HAR cable. This cable is needed if you have a Z06 car that does not have a CD player in the back.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20807464702/in/album-72157651574414323/" title="COR-HAR cable"><img src="https://farm6.staticflickr.com/5822/20807464702_a249375d40_m.jpg" width="240" height="180" alt="COR-HAR cable"></a>
2. GM10-AUX. This box connects to the end of the COR-HAR cable with RCA jack outputs to whatever device you wish to connect to.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20194327274/in/album-72157651574414323/" title="GM10-Aux10 box"><img src="https://farm1.staticflickr.com/756/20194327274_03de05b377_m.jpg" width="240" height="214" alt="GM10-Aux10 box"></a>
3. Blackberry Music gateway and 12V adapter for the console. The blackberry music gateway will plug into the GM10-AUX. I am sure other media gateways that have worked.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20630178079/in/album-72157651574414323/" title="Blackberry Bluetooth Gateway"><img src="https://farm6.staticflickr.com/5692/20630178079_d5aacd16e3_m.jpg" width="135" height="240" alt="Blackberry Bluetooth Gateway"></a>
4. MPOW Phone holder. This holder is secured into your CD ROM player to hold your phone.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20628963658/in/album-72157651574414323/" title="MPOW Box"><img src="https://farm1.staticflickr.com/651/20628963658_f24f18f506_m.jpg" width="135" height="240" alt="MPOW Box"></a>
5. Any phone or bluetooth device you wish to use with the system. In my case, I used by iphone 6 plus.
Installation steps.
If you own a Z06, the hardest step was to locate the 3 and 4 pin cables. These cables are under the passenger footwell on the right hand side. The first photo shows how the wires are from the factory.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/19454951139/in/album-72157651574414323/" title="C5 Z06 audio aux cables"><img src="https://farm1.staticflickr.com/291/19454951139_2f7730cb59.jpg" width="375" height="500" alt="C5 Z06 audio aux cables"></a>
The second photo explains where the four pin wire is. Sorry for the blue LED my footwell.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20599214822/in/album-72157651574414323/" title="3 pin plug located"><img src="https://farm1.staticflickr.com/647/20599214822_4b023188a4.jpg" width="375" height="500" alt="3 pin plug located"></a>
Take the 3 and 4 pin connections and plug them into the COR-HAR cable. Run this cable down the side of the car. In my case I tucked the cable under the plastic siding by the carpet to the back of passenger seat as seen in the next photo.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20816934225/in/album-72157651574414323/" title="GM10-Aux under passenger seat"><img src="https://farm6.staticflickr.com/5698/20816934225_037df38975.jpg" width="500" height="281" alt="GM10-Aux under passenger seat"></a>
In some cases the GM10-AUX box is not immediately recognized by the car. When this happens, you will see and digital "Err" show up when you press the AUX button on your stereo. To resolve this issue, turn your car to the "ON" position without starting the car, unplug the GM10-AUX from the COR-HAR cable and plug the box back in.
Plug your bluetooth media bridge into you console using a 12V adapter . Once this is done, connect the RCA cables of the GM10-AUX to the blackberry media bridge.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20630177919/in/album-72157651574414323/" title="Blackberry gateway in console"><img src="https://farm1.staticflickr.com/683/20630177919_8740df8a63_n.jpg" width="320" height="180" alt="Blackberry gateway in console"></a>
At this point, you should try and connect your bluetooth device to your the Blackberry media bridge. If your device connects, turn on your car, change the radio to AUX, and play music on your phone. On the stereo screen you should see a "Disc 1 Track 1' text that shows the GM10-AUX box is working and your music should be playing.
Congratulations! You have connected your phone/bluetooth devices to your cars stereo system.
Install your MPOW phone mount.
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20548344249/in/album-72157651574414323/" title="Mpow CD mount point for phone."><img src="https://farm6.staticflickr.com/5645/20548344249_115e0bbabc.jpg" width="442" height="500" alt="Mpow CD mount point for phone."></a>
Enjoy the usage of your system. The nice part about using your phone is that you can run your music and the navigation at the same time.
Vertical Music mode:
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20807464842/in/album-72157651574414323/" title="MPOW image vertical"><img src="https://farm1.staticflickr.com/612/20807464842_086f61f11e_n.jpg" width="320" height="180" alt="MPOW image vertical"></a>
Using Map with music in the background:
<a data-flickr-embed="true" data-header="false" data-footer="false" data-context="false" href="https://www.flickr.com/photos/18928073@N00/20630177169/in/album-72157651574414323/" title="MPOW sideways phone"><img src="https://farm1.staticflickr.com/722/20630177169_9ff05f460a_n.jpg" width="320" height="180" alt="MPOW sideways phone"></a>
The only downside of this setup is that the 12V AC connection in center console is always on. When I leave my car, I have to unplug the 12V adapter for the Blackberry. If any forum members have a good solution regarding this always on 12V adapter in the console, I would like to hear about it.
Thanks.
Plugs right into the radio...
Then you can get a 30 pin Bluetooth Receiver from Best Buy and plug it in....
You control everything from the radio, or your smart phone or ipod...VERY simple
My install I just leave the receiver in the console....
Then you can get a 30 pin Bluetooth Receiver from Best Buy and plug it in.... You control everything from the radio, or your smart phone or ipod...VERY simple
