turn signals
Old Aug 27, 2015 | 11:26 PM
mikeurbas's Avatar
mikeurbas
Default turn signals
I have a 2000 vette. the front passenger side turn signal works intermittently. does anyone have an idea on what is causing this?
Old Aug 28, 2015 | 07:04 AM
dadaroo's Avatar
dadaroo
The front housings typically get hot due to the DRLs. Eventually it will melt a hole in the plastic housing top and let water in. This can corrode the socket and fail the bulb after getting wet.
Easy bulb access video.
Picture of socket locking tab at Post 49.
http://www.digitalcorvettes.com/foru...=127459&page=4
Mr. Sam
Old Aug 28, 2015 | 07:52 AM
runner140*'s Avatar
runner140*
https://www.youtube.com/watch?v=BaUEoD2CH4k
Mr. Sam
Junkman also has many other videos....Used his vid recently on a waterpump change.
Old Aug 28, 2015 | 10:23 AM
mikeurbas's Avatar
mikeurbas
Originally Posted by 8VETTE7
If it is one side ONLY and always that same side then you need to examine the socket and wiring to the socket.
If you have both sides working intermittently then the MOST likely cause is the emergency flasher. Eflasher services both regular signals and emergency flashers.
Here is a thread with your options for correcting BOTH working intermittently:
https://www.corvetteforum.com/forums...post1589443564
it is one side only
Old Aug 28, 2015 | 06:53 PM
LoneStarFRC's Avatar
LoneStarFRC
AJ be a good dood.......
Old Sep 14, 2015 | 04:49 AM
sirdano's Avatar
sirdano
My 98 was doing this and I though is was a bad bulb. Visually looks okay but you have to look at the drivers side and will see that the bulb is pushed down in the socket more on drivers side. My passenger side was 1/2 sticking out of socket. I had to push back in with pliers now works good
Old Sep 30, 2015 | 11:41 AM
02Zvert06's Avatar
02Zvert06
Old Sep 30, 2015 | 01:57 PM
Johnny wangwang's Avatar
Johnny wangwang
If anyone has this issue with BOTH sides and doesn't have the time to fix it right then and doesn't want to cause an Accident....go get a bottle of MAF spray cleaner and spray a good amount of it in the front of the Emergency switch. Let it dry and your Turn signals should work for a little bit again.
To turn signals
