Can loading wrong tune fry pcm?
Old Aug 28, 2015 | 08:53 PM
robert1989's Avatar
robert1989
Default Can loading wrong tune fry pcm?
So, I sent my PCM out to get tuned to a stock tune. It was a PCM I purchased from someone parting out a 1998 Camaro SS.
Turns out the tuner (after much beating around the bush) loaded a 2001 trans am tune onto a 1998 LS1 pcm. He said he used CATS to do it.
With that said, is my PCM done?
I'm willing to bet it is. He asked me to send it back to him to re-tune it I did of course.
Old Aug 29, 2015 | 09:04 AM
dadaroo's Avatar
dadaroo
Performing a reprogram should not fry the PCM. He just needs to put it back to your 98 VIN correct status.
Mr. Sam
Old Aug 29, 2015 | 06:39 PM
Rookieracer's Avatar
Rookieracer
The 97-98 Ecms use a different pin assignment harness for programming on the bench. There are some differences in the +12v locations.
I'll have to check the pin outs, but if I remember correctly you may have brick on your hands.
Old Aug 30, 2015 | 07:51 AM
dadaroo's Avatar
dadaroo
I looked and it is a bit confusing. In 98 C2 is Blue and in 01 C1 is Blue.
However if you compare these two Blue connectors they are the only ones that have 12 volt inputs. There are only three 12 volt inputs. Pins 19 and 20 are the same for both years. In 98 the other is pin 61. In 01 the other one is pin 57.
If they used the 01 pin out to program it is should still be OK since in 98 pin 57 is not used for anything.
Mr. Sam
To Can loading wrong tune fry pcm?
