what is "normal" oil pressure range ?
Old Aug 22, 2002 | 10:47 AM
C5 CU's Avatar
C5 CU
Default what is "normal" oil pressure range ?
I added one quart of Mobil 10w30w. I noticed my cruising (50-70mph) oil pressure was 50. As I recall my prior pressure was always about 40-43. What is the normal oil pressure at 1700 to 2000 rpm (?) and if mine has increased (?) could that be result of mixing 10w30w with 5w30w? -- thanks.
Old Aug 22, 2002 | 10:59 AM
Phil97SVT's Avatar
Phil97SVT
Default Re: what is "normal" oil pressure range ? (david sanders)
40+ is good.
Phillip
Old Aug 22, 2002 | 11:09 AM
cjones's Avatar
cjones
Default Re: what is "normal" oil pressure range ? (Phil97SVT)
What are most people getting abobe 4500rpm at WOT?
Old Aug 22, 2002 | 03:08 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: what is "normal" oil pressure range ? (cjones)
I don't usually look at my oil pressure gauge at WOT...but that's just me!
Old Aug 22, 2002 | 08:52 PM
carpe dm's Avatar
carpe dm
Hi Dave: Mixing the oil probably had no real effect. My car usually runs 50+ until it warms up and then it drops back to 40 lbs and stays there at highway speeds. :)
To what is "normal" oil pressure range ?
