Hvac what do u need to remove for this view?
Old Sep 2, 2015 | 01:27 PM
sweetbeard's Avatar
sweetbeard
Default Hvac what do u need to remove for this view?
Pic taken from another thread so thank you brother...
But what do u need to remove to see this view I currently have the battery and tray out and was going to rip into the fender but need to know exactly where this is please...
Old Sep 3, 2015 | 06:52 AM
dadaroo's Avatar
dadaroo
You need to remove the right wheel and wheel well liner. There are a number of screws including some that go in vertically at the liner bottom. These are near the back, closer to the door.
Old Sep 3, 2015 | 11:08 AM
StingrayRebel's Avatar
StingrayRebel
pull the fender
Old Sep 3, 2015 | 11:32 AM
Patches's Avatar
Patches
Here a couple of shots of my '02 coupe.
Old Sep 3, 2015 | 11:54 AM
73Corvette's Avatar
73Corvette
Dang your car is pristine ... do you drive it? Beautiful car
Old Sep 3, 2015 | 12:24 PM
dadaroo's Avatar
dadaroo
OP, most HVAC line issues seem to be from battery acid on the small plastic vacuum line that is below the battery and can be found and fixed without removing the fender.
Hope that is the case for you.
Old Sep 3, 2015 | 01:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
In BOTH front wheel wells,, there's a small access panel at the rear of the fender liner. Remove the wheel and then remove the screws that secure the panel. There are some UNDER the car also. That will provide you enough access to get to the fire wall area.
To Hvac what do u need to remove for this view?
