Clutch Remote Bleeder
Old Sep 8, 2015 | 09:34 AM
don37's Avatar
don37
Veteran: Canadian Forces
Originally Posted by wcsinx
I have one that I got from Tick. It hasn't leaked. I like the fact that I can purge all the fluid from the slave. I used to do the turkey baster fluid swap at the MC reservoir, but that's tedious, messy, and not as thorough IMHO. I didn't like having that remote bleeder line so close to the header pipes however, so I slid a heat sock over the bottom half of the line (all the way to the slave fitting).
I used a tick performance remote bleed line for years without issue. Was always so grateful i could remove the cooked fluid directly from the slave cylinder - in under 15 mins. Unfortunately given my prior experience of bleeding the clutch with the stock bleed screw i have no confidence i could install a new line in my blue devil....
Old Sep 8, 2015 | 09:57 AM
k24556's Avatar
k24556
Here's how I solved the problem of a bleeder ruining the engine bay end of the remote hose [bought it from Tick several years ago], a 1500 psi needle valve I connect my Mittyvac to the brass nipple pull a vacuum, open the valve and keep pouring in the reservoir until the fluid runs clear in the hose:
