I would like to find out how I can reduce the temp at which the fans come on. I have changed the coolant with the standard 50/50 dex Cool and added a 180 thermostat. I would like to adjust the temperature at which the fans come on. The car currently does operate at a temperature that "is normal for what I've read here" but I want to reduce it. What is the easiest option, if any for me?
2) Install an aftermarket device that will turn the fans on at a lower temp.
Keep in mind that the fans will only run at vehicle speeds below 35 mph if you do option 1. That's because the C5 PCM is set to command the fans OFF at speeds above 35 irrespective of coolant temp.
Some option 2 products WILL allow you to keep the fans on at speeds above 35. I have the following one that allows that:
Realistically if your cooling system is in good working order then air flow through the radiator with the fans just free wheeling at speeds above 35 will keep the coolant temps in check.
Would it not be hard on the motors to try and overcome the air being brought in over 35MPH? I'd think so.
No, if anything, they'd be assisted by the airflow due to the angle of their blades, etc, but that's not the main thing at play here. Remember: these motors are NOT designed for constant operation, nor do they need to be. If they were, they would cost several orders of magnitude more than they do now. $$$$
HTH
For normal driving conditions... I believe that if your going over 35 MPH and you NEED fans to cool your engine temps down... You have a problem other than needing cooling fans. Just sayin
Even if you add a lower thermostat the engine will not run any cooler until you lower the fan settings----The stock settings in my opinion are way to late as to "on temperatures"
With an 180* thermo I would set the fans as such:
#1 fan ON at 195* and OFF at 187*
#2 fan ON at 205* and OFF at 196*
That is what I was thinking. Thanks for the thoughts. Now if anybody has something for sale that can help me acheive this......
you can get hptuners for around $600 and do it yourself, find someone you know who has hptuners and spend $100 on the credits to make the changes, or find a local tuner to do it for you
Easiest and cheapest way is to get a "mail order " tune---normally around $150 --Several vendors here on the forum---
Side advantage is if you ever do any more engine mods they will retune it for you for a lower cost
I don't agree that a mail tune is easiest... you have to remove the pcm from the car and send it off, wait for the tuner to make changes and ship it back, then reinstall it in the car... you will be down for at least a week, maybe longer... then when you get the pcm back cross your fingers and hope they did their job correctly, if they made a small mistake then you are back to square one and down for another week or more... if you take it to a tuner or find someone local that has hptuners it will take a matter of minutes to reprogram the fans and you won't have to take your car apart or wait for an extended period of time... if you take it to a local tuner the same rule almost always applies, once you get tuned at their shop whenever you go back for changes you pay a substantially discounted rate, usually around $100-150 for retunes
how much are you looking to spend?... a friend of mine is a vendor of hptuners, I believe it is right around $600 for the pro setup... it sounds expensive but you will probably end up using it quite a bit more than you think and you can also make your money back by charging your buddies to do stuff like this to their cars
