question on AC controls
Old Sep 9, 2015 | 02:28 PM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Default question on AC controls
I replaced my AC controls with a unit from a 99 into my 04. After swapping out the unit, I now have heat blowing from center and drivers side, and cold air from the passenger side. This when it is in AC mode.
When I move everything to heat, both sides heat. Anyone know what could cause this? Seemed to be a plug and play and was working fine with old unit. Only replaced due to no lights, display. Are the units not compatible?
Old Sep 9, 2015 | 02:48 PM
73Corvette's Avatar
73Corvette
I guess both controls were dual climate control?
You know there is a simple fix for the lights?
https://www.corvetteforum.com/forums...splay-fix.html
Old Sep 9, 2015 | 03:20 PM
dadsturn's Avatar
dadsturn
yes, fully aware there is a fix but decided to just swap out. both units are dual control.
Old Sep 9, 2015 | 03:44 PM
dadsturn's Avatar
dadsturn
believe I found the problem. ill try to use fuse 27 reset.
Old Sep 9, 2015 | 03:57 PM
73Corvette's Avatar
73Corvette
kewl... please post your results Thanks
Old Sep 10, 2015 | 07:18 AM
dadaroo's Avatar
dadaroo
The Dual control units can be swapped between all years.
Old Sep 12, 2015 | 04:55 AM
dadsturn's Avatar
dadsturn
fuse 27 did the trick. removed, let sit. plugged back...all good.
To question on AC controls
