C5 Front Shock Bolts Help
Old Sep 14, 2015 | 11:15 AM
C5Enthusiast's Avatar
C5Enthusiast
Default C5 Front Shock Bolts Help
I'm in a bind. My parts - tech manuals are gone (I'm moving and they were packed/shipped to my new home.). I need the front shock bolt size. My garage is a mess due to the pack out and I've misplaced the bolts. Can someone look the size up for me? 2000 C5 Coupe....
Thanks.
Old Sep 14, 2015 | 11:54 AM
73Corvette's Avatar
73Corvette
Thanks.
I'd check with the local GM dealership and see if they have any... and then ask about size if they don't.... FYI...I zip tied the shocks in the compressed position then put the TOP in first... lube the shock shaft with some WD-40 so it won't bind on the bushings... then you can cut the bottom free and guide it into place and jack up the rotor till the bolt holes are where you need them to bolt it back up.
Old Sep 14, 2015 | 01:18 PM
NITRO UK's Avatar
NITRO UK
Hi mate
I just dug my old ones out for ya .
13mm bolt head
2 1/4"long
Thread is m8 x 1.25 pitch
Will need four nuts as well
Would send em to you but that might take some time lol
Old Sep 14, 2015 | 01:22 PM
zachaeous's Avatar
zachaeous
Default bolts for front shock
The bolts for the front shocks are M8x1.25x55 #11516494 bolt.
The nuts are #11517031.
Old Sep 14, 2015 | 05:41 PM
C5Enthusiast
Thanks guys....Appreciate the help. This is a temp fix only....Just have to get my shocks on and wheels mounted to move the car....
To C5 Front Shock Bolts Help
