New wheels no tpms !!!!
Old Sep 14, 2015 | 08:50 PM
03bluemule's Avatar
03bluemule
Default New wheels no tpms !!!!
What will happen if I don't use tpms . I know it will show a code but any other problems . 99 frc thank's.
Old Sep 14, 2015 | 09:24 PM
73Corvette's Avatar
73Corvette
You'll just have to go old school to keep up with the air pressure in your tires and use a tire guage... it is a nice feature without a spare to be able to check your tire pressure frequently and know it's going to give you a heads up if one starts going down...
that being said... won't hurt a thing, we did it for several years without it.
Old Sep 14, 2015 | 09:31 PM
No problems running the car without the TPMS but no visual warning of losing air pressure either.
Old Sep 14, 2015 | 09:54 PM
03bluemule's Avatar
03bluemule
Thank's guy's didn't know if there would be reduced power or limp mode .
Old Sep 15, 2015 | 11:07 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
No reduced power or limp mode.
The DIC will show an error message each time you start the car. You can clear it with the reset button.
I drove my '99's with different sets of wheels fairly often and some sets did not have TPMS. It doesn't hurt anything, it just makes you clear it once each trip.
Old Sep 15, 2015 | 11:09 AM
73Corvette's Avatar
73Corvette
I'm sure with a Tech II someone can eliminate that if you desire to do so...
My bad... this can NOT be done on 1997- 2000 models.
Thank you guys for being kind, and correcting me...
If you don't want to wear out your reset button or get tired of seeing the message it looks like you'll have to get some working TPMS....
Old Sep 15, 2015 | 11:23 AM
QCVette's Avatar
QCVette
The '99 did not have an option for no TPMS. So I don't think the Tech 2 can change it.
I think the only ones that a Tech 2 can change are the '01-'04 cars since the Z06 had that option.
Old Sep 15, 2015 | 11:28 AM
73Corvette's Avatar
73Corvette
Thanks for the heads up... I know there are lots of differences, just didn't know about the TPMS...
Old Sep 15, 2015 | 11:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% CORRECT! In 2001, the ZO6 was released and did NOT come from the factory with the TPMS Option. Thus, it was able to be deleted in the BCM using the Tech2.
However, IF,, you desire to have TPMS on a ZO6, you can also ADD it on by enabling the RPO in the BCM and adding the Pressure sensors. I have them on my 02 ZO6.
That being said, You can NOT remove that option from the 97-2000 BCM!
Hope that clears up the TPMS Info
YES,, You will need to clear the messages in the DIC each time you start the engine if you don't have the sensors installed.
Why not just install them???
Bill
Old Sep 15, 2015 | 12:50 PM
03bluemule's Avatar
03bluemule
Thank's for the info guy's . Well Bill there not cheap and hear so many have trouble programing aftermarket sensors .
Old Sep 15, 2015 | 01:03 PM
73Corvette's Avatar
73Corvette
IF you get sensors... program them BEFORE they go in the wheels... make sure you mark them and they go in order... that way you know, if they work or not and you won't have the headache of mounting, unmounting, remounting... yada blaaaa
Old Sep 15, 2015 | 04:24 PM
03bluemule's Avatar
03bluemule
Good idea 73corvette Thank's !!
Old Sep 16, 2015 | 05:36 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
The technology keeps improving and I would be really surprised if there was any problem at all. I just changed my sensors last month - bought 4 new ones - boy have they changed - they are SMALL - about 1/4 inch thick, and less than a 1/2 square. Good for 6 years or so. They programmed just as the Corvette manual instructs. The installer uses a handled computer but they still need to use a magnet which he was reluctant to do.
Go for it.
Old Sep 16, 2015 | 07:40 PM
03bluemule's Avatar
03bluemule
Mines a 99 frc I see titan on tirerack are they a good part or maybe the one's on ebay ?
Old Sep 17, 2015 | 01:33 PM
Road Runner
I would stick with ones you get locally so if there is any problem, you can resolve the issue immediately.
Old Sep 17, 2015 | 11:50 PM
wrmiles's Avatar
wrmiles
You may have trouble finding shops that will do work that could be considered disabling TPMS
(mounting tires, etc.) since there is a potential large fine to them from the feds.
To New wheels no tpms !!!!
