C6 throttle body on C5
Old Sep 15, 2015 | 02:47 PM
RAS6582's Avatar
RAS6582
Default C6 throttle body on C5
I just got a new C6 TB and the Casper's wiring adapter. I realize that this TB doesn't have the nipple that runs to bank 2 valve cover. I'll plumb that in right behind the TB. I also notice that this TB doesn't have the coolant lines running to it. I'm assuming these lines can be plugged but am not certain. Any help is appreciated.
Old Sep 15, 2015 | 05:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! I installed a Ported FAST and a C6 TB way back in 04. I had the same issue. If you look on the drivers side of the plastic air tube, you will see a FLAT area. I drilled a hole on that flat area and installed a BRASS 90 Deg screw in fitting with a barbed fitting for a vacuum line. I ran the vacuum line UNDER the TB and over to that fresh air vent. Worked FANTACTIC!
As for the TB Coolant lines. You can do several things.
- Plug them
- My 02 ZO6 (LS-6) and any 2001+ LS1 engine does NOT have a rear cross over vent line. I wanted to add one to prevent the possibility of steam build up on my modified LS engine.
SO,,,,,, I removed the rear vent blank plugs, and I purchased a second 2001+ FRONT cross over tube and installed it backwards on the rear vent. I used a rubber hose to connect that vent line into the front vent line using a metal "T" fitting. (right where the C5 TB coolant hoses connected to the TB)
2001+ C5 Front cross over pipe mounted backwards and attached with a rubber hose:
You will ALSO notice that I extended that damn SHORT vacuum line.
I installed a FAST 90 and the vacuum port for that line is in a different place but,,, the extension sure does help installing a normal C5 OEM Manifold!!!
