installing torque converter and 3.42 diff
Old Sep 17, 2015 | 08:02 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Default installing torque converter and 3.42 diff
doing this in pirateslife4me car. got it all tore down and ready to drop the cradle. this car has the F45 shocks, so we are removing those. so, off goes the module.
Old Sep 18, 2015 | 12:22 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Transmission and diff removed. even left the torque tube in the car.
Old Sep 18, 2015 | 12:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you don't use the GM Tech2 to remove the RPO from the BCM,, you will be speed limited to 80 MPH and have all sorts of messages and DTCs!!
Old Sep 18, 2015 | 12:39 PM
flyingillini's Avatar
flyingillini
Please elaborate. I would like to do the diff and torque converter on my car and this is not clear.
Old Sep 18, 2015 | 12:47 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
He is adding resistors to compensate for the f45 removal.
Old Sep 18, 2015 | 12:48 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
He is refering to the removal of the f45 shocks.
Old Sep 18, 2015 | 06:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HE STATED THAT HE IS REMOVING THE "MODULE" If he is depending on the resistors,,, the ENTIRE SYSTEM must be retained and WORK!
So,,, you can NOT remove any F-45 suspension parts (other than the shocks)
Old Sep 18, 2015 | 06:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have to remove the F45 Real Time Dampening RPO from the BCM if you want to disable the F45 Real Time Dampening
If you install a different stall speed converter, you will have to have the PCM tuned to have the transmision shift properly.
BC
Old Sep 18, 2015 | 07:11 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Did not know the module that connects to the upper arm had to stay. Can be easily put back on.
Old Sep 18, 2015 | 07:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats why I am a fan of removing the entire RPO and not having to worry about ALL of the system components working properly.
BC
Old Sep 18, 2015 | 08:52 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
He has hptuners to fix the shift points and knows someone with a tech II.
Old Sep 20, 2015 | 12:58 AM
KoreaJon's Avatar
KoreaJon
The TC and 3:42's are gonna be a fantastic upgrade! I installed a 3400 stall in mine, but left the 3:15's and the car felt like a different animal.
I used HP Tuners to adjust the shift points, pressures, and TC lockup points....It took a few tries, but I love how it performs....errr...performed!
Good luck with the swap!
KoreaJon
Old Sep 22, 2015 | 01:22 PM
tiojames's Avatar
tiojames
While it's apart I would check the drive shaft couplers-just in case.
Old Sep 22, 2015 | 04:08 PM
Fazdagt's Avatar
Fazdagt
I learned this the hard way after completing my A4 to Six Speed swap and using a trans harness from a car that didn't have the option.
Fortunately I have a friend with a Tech2 that can clear things up and I don't think I need to be going over 80 until I can get together with him. There are so many warnings though!
To installing torque converter and 3.42 diff
