Leaf spring bushings
Old Sep 21, 2015 | 10:55 AM
xdmikey's Avatar
xdmikey
Default Leaf spring bushings
Can leaf spring bushings cause a clicking sound?
Very precise measured sound. I will jack up the car when I can and check top/bottom and side/side wobble but I'm thinking this is it.
My engine builder called it but he's known for engine stuff. After listening to him drive her into the garage I learned it wasn't coming from the front but from the rear.
Possibilities?
Thanks.
Old Sep 21, 2015 | 12:40 PM
Smoken1's Avatar
Smoken1
I would check your sway bar end links. Mine made the same noise
Old Sep 21, 2015 | 12:52 PM
xdmikey's Avatar
xdmikey
Thanks, I will.
The bushing on the left side is gone! I will also check the leaf spring bushing.
Old Sep 21, 2015 | 07:27 PM
xdmikey's Avatar
xdmikey
End links feel pretty good, as opposed to the fronts which were completely blown out. Compared to my front ones which beyond looking like a flat donut-they looked like two pancakes!
Left side leaf bushing is gone; right side looks to have about half an inch of bushing left and it looks good, unstressed.
Still would like to hear views on this.
Old Sep 21, 2015 | 07:56 PM
Smoken1's Avatar
Smoken1
If the end links are the old style plastic ones I would replace all 4 with the new metal ones
Old Sep 21, 2015 | 08:58 PM
xdmikey's Avatar
xdmikey
The front end links have been replaced by me. The rears will be replaced when I do the leaf spring bushings.
Old Sep 21, 2015 | 09:42 PM
Sam Handwich's Avatar
Sam Handwich
Are you going with a polyurethane bushing? I am curious because i have ordered p/u bushings for my sway bars. Trying to get a sense if swtching to p/u in some of the other locations is worth the time and effort.
Old Sep 22, 2015 | 10:41 AM
xdmikey's Avatar
xdmikey
Sam, I don't know but you've given me something to think about. I'm looking at leaf spring bushings, not sway bar bushings. I called the parts house my builder uses and they don't show a part at all. I have another source to talk to though.
For anyone: I should replace both, even if going stock, correct?
Old Sep 22, 2015 | 11:21 AM
Sam Handwich
I have found a couple of places that have p/u bushings for our cars. I think JEGS is a source.
Also http://www.energysuspensionparts.com which has a chat feature that is very useful.
To Leaf spring bushings
