HUD plastic trim
Old Sep 21, 2015 | 06:31 PM
See 8's Avatar
See 8
Default HUD plastic trim
The plastic trim on the dash Hud assembly recently cracked in the sun. How hard is it to replace? Any help would be appreciated.
Old Sep 21, 2015 | 06:43 PM
janky's Avatar
janky
I used this, worked fine.
http://www.c5hudbezel.com
Old Sep 22, 2015 | 03:36 AM
bill mcdonald's Avatar
bill mcdonald
You need to remove the dash.
You will need to pull the console bezel, hush panel, drop the steering column by removing 2 bolts, this will allow you to pull out the gauge cluster. remove a few bolts from the glove box. Then you can pull out the dash board
Once you have the dash out you can undo those plastic bolts holding the hud bezel in, that will probably just break, and install the new one and reassemble.
Old Sep 22, 2015 | 10:13 AM
See 8's Avatar
See 8
Default Hud Bezel
Thanks much I'll try it.
Old Sep 22, 2015 | 10:16 AM
See 8's Avatar
See 8
Default Hud bezel
Thanks, but I'm going to try it the way Janky suggested, it seem much easier
Old Sep 22, 2015 | 04:47 PM
oh1vette's Avatar
oh1vette
That's pretty cool- pics when done please
Old Sep 22, 2015 | 10:26 PM
SEC5's Avatar
SEC5
Default Do you need a bezel??
I was just thinking about throwing out one just about an hour ago... It's still sitting on my table from when I replaced my dash...
I replaced my dash because it had several "tabs" that were broken off. The new (used) dash had a bezel already attached.. I have an extra if you would like it?? NO CHARGE... just pay shipping and its yours!!
The dash isn't that hard to pull out, its actually much easier than I expected....!!!
Good Luck
Sec5
Old Sep 24, 2015 | 02:17 PM
See 8's Avatar
See 8
Default Hud Bezel
Good Luck
Sec5
Your offer is greatly appreciated, but I'm going to try Janky"s approach 1st
Thanks Again
Old Sep 28, 2015 | 11:21 PM
old stingray's Avatar
old stingray
Good Luck
Sec5
If this offer is open to anyone else I'll take it if 65 midyear doesn't want it,
Old Oct 21, 2015 | 09:48 PM
See 8's Avatar
See 8
Default Hud Plastic trim
I tried janky's suggestion, and it worked great. It was easy to install, and you can't tell that it was replaced
Old Oct 21, 2015 | 10:29 PM
Much easier than pulling the entire dash apart.
To HUD plastic trim
